Author: Subject: Gearbox to Engine sealant
minordelay
posted on 23/3/09 at 08:39 PM Reply With Quote
As above, I need a recommendation of the correct type of sealant. Bike shop uses heat proof non hardening stuff, (not rtv/silicone) there too thick and can clog the galleries.
I can order some through the shop for £80.00 a tube
Any suggestions welcome, it's for a gsxr600 if that helps.
cheers
nitram38
posted on 23/3/09 at 08:43 PM Reply With Quote
If it has to remain soft, then Blue Hylamar.
They use it on surfaces that have to be dismantled, like Rolls Royce aircraft engines and it withstands high temps.
daviep
posted on 23/3/09 at 08:59 PM Reply With Quote
LOCTITE 5900
mad-butcher
posted on 23/3/09 at 09:01 PM Reply With Quote
little trick told to me by an engine technician at RAF Sealand regards hylomar, put enough on a piece of plastic and allow the solvents to evoparate before using.
tony
clairetoo
posted on 23/3/09 at 09:09 PM Reply With Quote
My experience of blue hylomar is that it nearly disolves in hot oil , then collects in the oil strainer and blocks it - killing the engine
Not in my engine , BTW , but working in a bike shop many years ago I saw more than a few examples of this .
I wont put the stuff anywhere near an engine
Its cuz I is blond , innit
Claire xx
Will weld for food......
hillbillyracer
posted on 23/3/09 at 09:14 PM Reply With Quote
I've used RHODORSEAL which I've got from Partco in the past on similar jobs, it is a Silicone type product but not like the stuff you get in mastic guns, more paste like & more rubbery when it's gone off.
The way to avoid sealer blocking the oil pump etc is to use just enough, you should just see it strating to ooze out of the joint once it's all bolted tight but no more, then you know it's filled the joint but not left loads loose inside. Have a few practice goes on a short section to see how much is needed, probably less then you think!
nitram38
posted on 23/3/09 at 09:16 PM Reply With Quote
I have used it lots on engine rebuilds. Not only no leaks, but no horror stories either.
Website here
minordelay
posted on 23/3/09 at 09:54 PM Reply With Quote
I must admit that i'm confused by all of the choice.
Stuff I was shown at the Suzuki stealers was in a tube but thin, unlike rtv and when rubbed between 2 fingers didn't dry out and it spread almost like black grease.
I might try local branch of J&L industrial see what they can do
[Edited on 23/3/09 by minordelay]
pgtips
posted on 24/3/09 at 08:00 AM Reply With Quote
We use the WURTH SILICONE SPECIAL 250 products for all our engine builds or anything to do with oil seal. Not cheap but I must say the best one I have used in the last 20 years working for the motortrade. Let me know if you can't get it I see if I can get you a tube from our WURTH rep.
