mcerd1
posted on 24/3/09 at 02:17 PM |
FS - anual garage clearout (Stoneleigh?)
Its time to start thinking about clearing out all the extra bits again
some stuff could be posted, but I can take stuff to the stoneleigh show again to save the postage
(I know it still ~6 weeks to go, but I need time to sort it all out)
1 - carb off a sierra (pinto) I think its a webber of some kind, never seen it run - Free [Sold - Daddylonglegs]
2 - coil pack +plug, early type (untested) - £5 [Sold - dave r]
3 - 4x Mk3 Granada front uprights (no hubs) different to sierra one - Free
4 - 2x Pinto 2.0 carb'd type heads both fairly manky from engines that havn't run for years £5/head (old cam's, valves.... included
if you want)
5 - 2x Pinto 20 Blocks (carb'd), both with a piston stuck
6 - Std. 2.0 Pinto flywheel - £5
7 - pair of Granada driveshafts (with 2 old CV joints)
8 - 3x non-return valves for a mk1 focus steering rack (not supplied with most recon racks, and the old ones arn't easy to get out :mad - £7
each
9 - 2x Focus alloys New 6"x16" 4x108, ET52.5 - £45 the pair
10 - 1 pair of Sierra Hubs, no bearings (I have both sides even though there is only one in the pic)
they were all blasted a while back and the uprights where powder coated but they are a bit marked /chiped now
the pinch bolt threads have a little damage, but all you need is slightly longer bolts and a nut
I guess they are worth £15
11 - Granada calipers, same as the 260mm ABS sierra ones, good as exchange ones - £5
I'll add more as I find it - there is a big pile
shout if you want photos of any of it
there are still other odds and ends of mostly mk3 granada / pinto bits - give me a shout if you need something and I'll have a look
also avalible are loads of old PC parts.....
PS - I can also accept beer and food as payment at the show
-Robert
[Edited on 27/4/09 by mcerd1]
[Edited on 28/4/09 by mcerd1]
filiperosa
posted on 24/3/09 at 03:31 PM |
How much for the Pinto blocks?
mcerd1
posted on 24/3/09 at 03:36 PM |
well nothing really, but if I lug them down to stoneleigh - call it £5 the pair
but they are more or less bare blocks - no crank, on sump.......
Daddylonglegs
posted on 24/3/09 at 04:19 PM |
I'm up for the carb
I'll only be there on the Sunday though.
JB
mcerd1
posted on 24/3/09 at 04:27 PM |
quote: Originally posted by Daddylonglegs
I'm up for the carb
JB
its your then
I should be there both days
u2u sent
dave r
posted on 24/3/09 at 05:46 PM |
yes please to the coil pack
mcerd1
posted on 31/3/09 at 09:14 PM |
more bits added ^^^
mcerd1
posted on 27/4/09 at 10:22 PM |
even more bits added ^^^
londonsean69
posted on 28/4/09 at 09:55 AM |
Cheers for first dibs on the hubs, but I have a set now.
mcerd1
posted on 28/4/09 at 10:31 AM |
thanks for the quick reply (edited ^^^)
