<<  1    2  >>
New Topic New Reply
Author: Subject: Stiffer chassis, the solution!?!
thommy2
posted on 17/2/04 at 08:57 PM Reply With Quote
HI there!
I would like some opinions here about a thought of mine.
Tractors, or the things farmes use for on the land, can be equiped with 6-cilinders. Those engines aren't equiped with balance axes, or whatever you might call them in good english.
Those engines are part of the frame, and it makes them verry stiff right?
So, why not do that on a locost, we use a BMW six inline.
Why not bolt the entire engine to the spaceframe without rubber, the engine is fiberation free right??
Or has it been done yet?
reactions please...
Thom
Metal Hippy
posted on 17/2/04 at 09:08 PM Reply With Quote
I may be wrong, but my first thought is that with the stiff suspension in the kind of cars we're building you'll vibrate the thing to pieces over time.
Tractors have biiig tyres and usually work on softer ground which I would imagine helps to dampen the vibration a lot.
Also if you've ever driven or ridden in a tractor you'll find that they're not exactly the most quiet of machines mostly thanks to everything vibrating on them.
Cock off or cock on. You choose.
sweston
posted on 18/2/04 at 01:30 AM Reply With Quote
My 2 cents worth, as I own a Tractor and locost.
My Massey Ferguson 28, yes the engine is bolted to the gearbox/back axle and they are the chassis. Tractors run at low revs, you have very low gears. Its all about low down power and torque. It has a huge "heavy" flywheel that I need a hoist to lift. My tractor never gets much above 1500rpm so with a well padded seat, low pressure in the tyres and nice soft ground the vibration is acceptable. Also with the PTO you dont want springs/suspension.
Top gear and full rev's and its a real scarry ride even on a nice smooth road.
If you ever see the Tractor Pulling monsters, well they prepapre the engine as if it was for a F1 race. Its all balanced etc as a proper race engine would be.
Mind you a friend with an old Alvis looked at the tractor and remarked how similar his engine & gearbox where !
Metal Hippy
posted on 18/2/04 at 01:59 AM Reply With Quote
To add to the above (as I said to Thommy in Messenger) I'd have said it may not be an issue on race cars that can be rebuilt after each race, but that would involve a fair bit of cost... but would be needed if bits weren't to fail after a short while giving it some welly on a road that isn't smooth as silk...
thommy2
posted on 18/2/04 at 07:46 AM Reply With Quote
You are all right in that.
Just for information, I work at a farm to. I use to ride de Case CS86, quit a new puller. But when driving on the road, it's goes smooth as a baby
The large advantage of a 6 inline, v12, is that there are no secundairy viberations. ( I just quote my brother, a car engineer, who worked at ferrari, upgrading the Colombo V12)
So that's why I guess there are no damaging viberations.
andyps
posted on 18/2/04 at 10:56 PM Reply With Quote
I guess the main difference is that the engine is designed as a stressed member for these applications.
The Ferrari F50 is one of few road cars which use the engine as a chassis member - it is bolted directly to the bulkhead and the suspension mounted to it, but that engine was apparently based on the Formula 1 engine design.
Most of the engines which might be used in a locost were never designed for this type of stress to the castings.
stephen_gusterson
posted on 18/2/04 at 11:44 PM Reply With Quote
engines in old cars might be similar - my old boss said the engine in his tr4a was from a tractor design
atb
steve
thommy2
posted on 19/2/04 at 07:47 AM Reply With Quote
ok, anyway
We'll just try it, I let you know when we suceed
Terrapin_racing
posted on 19/2/04 at 09:15 AM Reply With Quote
Unlike McLaren F1, Ferrari F50's rear suspensions are directly bonded to the engine / gearbox assembly. This means the engine becomes the stressed member which supports the load from rear axle. Then, the whole engine / gearbox / rear suspensions structure is bonded into the carbon fiber chassis through light alloy. This is a first for a road car. Advantage: lighter still. Disadvantage: engine's vibration directly transfers to the body and cockpit.
As described in the section on the chassis, the engine is also a part of the car's structure. The engine sits behind the driver, between the transmission and the tub that forms the cockpit of the car. It is the only connection between the front and back of the car. The engine is therefore called a stressed member, meaning that it carries load and is subject to mechanical stress. The level of stress that a Champ Car can exert on the frame is one more thing that makes the engine so critical to success -- the engine is, mechanically, the entire midsection of the car's structure!
The engine and drive train of a Champ Car make up about one-third of the mass of the car. In a severe crash, the engine and drive train assembly separate from the front of the vehicle at a line just behind the driver in an attempt to protect the driver and dissipate energy.
Engine stressed member
If you engine is smooth enough not to transmit overbearing vibration to the rest of the chassis it makes a lot of sense to brace you chassis against the biggest stiffest heaviest component it carries, and make use of its strength to do some of the load bearing work.
In 1963, a revolutionary chassis structure appeared in Formula One, the championship-winning Lotus 25.
Once again developed by Colin Chapman. Chapman used the engine / gearbox as mounting points for rear suspensions in order to reduce the width of his car as well as to reduce weight.
In particular, reduced width led to lower aerodynamic drag. Of course, the engine / chassis must be made stiffer to cope with the additional stresses from rear axles. Today, F1 cars still use this basic structure.
Along with the chapman strut this did find its way onto some Lotus road cars.
Although its use has been limited in Car use. It used to be a popular construction method for Motor bikes with bike like the Honda Super/Dream and the GPZ900R using the design instead of a conventional chassis. Rescued attachment ferrariengine.jpg
James
posted on 19/2/04 at 09:19 AM Reply With Quote
Originally posted by thommy2
ok, anyway
What about just following Cymtric's chassis mods- these will double the torsional stiffness (and reduce the weight!).
This is a simple and tried and tested route.
James
Terrapin_racing
posted on 19/2/04 at 09:31 AM Reply With Quote
You could also use a slight compromise -
I you look at my photos you'll see in the suspension areas and engine mounts some yellow and green looking plastic materials these are polyurethane and Green Nyloil (RS Components) machined as mounts and bushes on engine brace bars. Dampens out the vibration but des not move like rubber!
Just remember that there was an issue with Jack Hammer users getting "white finger"
What do racers get if the vibration is through the seat of the pants?
200mph
posted on 19/2/04 at 09:33 AM Reply With Quote
well white bum would be better than brown bum..... if you get that
mark
Terrapin_racing
posted on 19/2/04 at 09:34 AM Reply With Quote
I believe it leads to long term stiffness - could be an advantage to some racers! lol
thommy2
posted on 19/2/04 at 09:35 AM Reply With Quote
ok, anyway
James
James, what is that Cymtric's mod you talked about??
Well, going the easy way is simple, but not enough for inventors.
Indeed, instead of rubber, we could use less damping material, but we also have to adjust the enginemount. I will post a drwaing later.
James
posted on 19/2/04 at 01:45 PM Reply With Quote
Read this thread:
http://www.locostbuilders.co.uk/viewthread.php?tid=1738
The long post by Cymtrix explains what you can do. He seems to know what he's on about (in my layman's view) and he uses a Finite Element Analysis system to work out how to make the chassis stronger.
There's a a link somewhere to a site with a picture of the mods- anyone got it as I can't find it? Thanks.
HTH,
James
timf
posted on 19/2/04 at 02:01 PM Reply With Quote
look in the photo archive under cymtrix
James
posted on 20/2/04 at 10:26 AM Reply With Quote
Thanks Tim, there was also a link to a page that was presented as a Word document. A load of text at the top and a picture of the chassis below- anyone.
James
flak monkey
posted on 20/2/04 at 10:32 AM Reply With Quote
Yes i have a copy of that if i could work out how to attach it to this meassage i would post it anyone know how to attach a file? Unless this works....
I think it is the one you mean, 2 pages of word document, with several pictures in it
Edit: wow it worked
[Edited on 20/2/04 by flak monkey]
Sera
http://www.motosera.com
James
posted on 20/2/04 at 10:47 AM Reply With Quote
Nice one that man!
James
pbura
posted on 20/2/04 at 11:10 AM Reply With Quote
A US builder is using solid mounts on his rotary engine (another with little vibration), for limited street use:
http://autos.groups.yahoo.com/group/Locost_North_America/message/14810
Another benefit of stiff mounts is more efficiency in the drivetrain for acceleration. You would save that momentary lag as the engine winds up in its mounts.
I like the compromise proposed by Rob earlier, using Nylon or the like. Best of both worlds, really, in that harmonics would be damped while most of the stiffness would be maintained.
In my opinion, solid mounts are a "racer's edge" that probably wouldn't benefit a road car too much, while the negative aspects would be noticeable. Probably a close analogy would be very stiff springing.
Pete
Pete
Terrapin_racing
posted on 20/2/04 at 12:26 PM Reply With Quote
Tend to agree Pete. lot of racers use solid mounts - great, but there are penalties. I recently saw the havoc caused to the chassis tubes around the engine bay of a Hawk single seater (cracked welds etc.) - hence my slight compromise.
Incidentally Nyloil is very inexpensive and some of the firms manufacturing polyurethane bushes will sell you the stuff in colour coded bars/blocks - colour denotes shore rating (hardness) - . The four manufactured formulations of firmness (70, 80, 90, & 95 Shore-A) - they also can be very helpful with advice.
Rob
http://www.focussport.com/mounts.htm
[Edited on 20/2/04 by Terrapin_racing]
[Edited on 20/2/04 by Terrapin_racing] Rescued attachment polyurethane.jpg
thommy2
posted on 20/2/04 at 05:59 PM Reply With Quote
The Original
engine mount standard
This is the flexible aproach
engine mount new
engine mount new
This will give more strucute to the engine in the space frame.
Do you guys think it'll work?
[Edited on 20/2/04 by thommy2]
Terrapin_racing
posted on 23/2/04 at 02:54 PM Reply With Quote
I think you need to isolate the upper section from the frame. In your drawing the bolts will effectively be a solid mount.
You should use two bits of insulator - one onto the engine mount bracket and one to the frame. Then with a joint of some nature between the two pieces of PU. Mine use a dovetail.
Here is an Audi A3 polyflex bush mounting as an example Rescued attachment a3.jpg
madman280
posted on 15/8/04 at 12:24 AM Reply With Quote
engine as a stressed member
There was a one off 11 built in detroit in 1960 that used a slant 6 as a stressed member of the chassis. The 11 and 7 chassis' share allot in common. You can read how Colin liked the idea enough to use it in formula 1. http://www.lotuseleven.org/open_exhaust.htm
drmike54
posted on 16/8/04 at 05:07 PM Reply With Quote
Didn't the BAR Honda team blow some engines last year because the engine flexed excessivley under the chassis load and spun the bearings.
<<  1    2  >>
New Topic New Reply
