Author: Subject: Vapor dash questions
chrisg
posted on 29/3/09 at 08:21 PM Reply With Quote
I'm fitting a Vapor dash to my car which is powered by a fireblade engine.
Can I connect the bikes tacho output direct to the Vapor's tacho input?
Can I use "ordinary" wire to extend the speed sensor and temp sender wiring?
Any help gratefully received!
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
lotusmadandy
posted on 29/3/09 at 08:32 PM Reply With Quote
I have a vapor and the tacho is connected
to the coil output,on a car engine and it works fine.the speedo and temp sender need a proper extension cable as the wires are too fine to solder(i have tried and it dont work)the cable is only about fiver.Its not worth buggering about with wires when the correct parts are so cheap.Nice bit of kit though and works great.
[Edited on 29/3/09 by lotusmadandy]
Scoobythedog
posted on 29/3/09 at 09:49 PM Reply With Quote
I used ordinary wire to extend these and it works fine.
Scooby
chrisg
posted on 30/3/09 at 04:37 PM Reply With Quote
Thanks!
chrisg
posted on 14/4/09 at 04:44 PM Reply With Quote
Just to ressurect this, I never did find out if I could attach the tach output direct to the vapor rpm sensor,
anyone know?
Chris
chrisg
posted on 15/4/09 at 07:11 PM Reply With Quote
Anyone in the same boat - don't bother asking Trail tech - they don't know!!!!
Chris
[Edited on 15/4/09 by chrisg]
