gingerprince
posted on 31/3/09 at 06:39 PM |
Sierra Drum Brake Orientation
I've got my back-end apart (oo err) whilst I paint my chassis, and I've notice that comparing my rear drums to Haynes, they look the wrong
way round.
This is the picture from Haynes, where 'A' is the leading show, so it's clearly the left-hand-side of the car: -
  Sierra Brakes from Haynes Manl
However, the orientation of the brakes on the left-hand-side of my car looked like this: -
  Drum Brake 1
Whereas the right-hand-side looked like this (the same as the Haynes picture): -
  Drum Brake 2
So to me it seems like it's the wrong way round. My guess is that I should swap sides, and see if it's possible to re-route the handbrake
cable to enter the drum from the front rather than the (current) rear configuration.
But before I do, can someone please confirm whether mine are currently wrong, and whether it actually makes a difference at all? And how do others
with MK's have their handbrake cable routed?
I didn't build it by the way, so if it's wrong I'm absolved
Keith Weiland
posted on 31/3/09 at 06:55 PM |
Yes, yours are wrong, I just removed mine this week from my donor and they were the way they are in the diagram and the cable enters from the front.
flak monkey
posted on 31/3/09 at 07:10 PM |
I put mine on upside down and on the wrong side so the cable enters from the back and the leading shoe is still the right side.
Its a common thing to do, and they work really well. No probs on the brake rollers.
Sera
http://www.motosera.com
Keith Weiland
posted on 31/3/09 at 07:14 PM |
If you put them on the wrong side and upside down the cable would enter from the front. Sounds like you just have them upside down
flak monkey
posted on 31/3/09 at 07:18 PM |
Oh yeah only half with it today!
Sera
gingerprince
posted on 31/3/09 at 07:59 PM |
Cheers both. I'll have a look tomorrow to see what will best suit the handbrake cables.
Incidentally, what impact would it being the wrong way have had? Would it have affected the self-servoing at all, or the self adjuster, or not really
much at all?
Thanks, Simon
Keith Weiland
posted on 31/3/09 at 08:10 PM |
I shouldn't think it would make much difference if at all on drum brakes which way round they are or if the are upside down. If it were me I
would leave it the way it is, I assume it passed SVA that way and works so why mess with it.
Macbeast
posted on 1/4/09 at 07:01 AM |
I tried putting them on upside down but the the holes in the backplate are not evenly spaced so it didn't work.
I have them swapped left for right and it all fits but haven't tried them in anger yet.
JAG
posted on 1/4/09 at 07:20 AM |
Drumbrakes work much better if they are on the correct side and the right way up. The direction of drum rotation and the lining material position is
quite important.
Fitting them as you have them will reduce the effectiveness of the foot brake and increase the effectiveness of the handbrake (only in the forward
direction).
If you can cope with these limits, and the slightly difficult handbrake cable routing, then they will work fine the 'wrong' way round.
Justin
gingerprince
posted on 1/4/09 at 06:08 PM |
Cheers all.
I'm going to try and fit them the right way around. I can't put them upside down, the holes in the upright don't then match the
back-plate. I've never been happy with the performance of the rear brakes (MOT I had to press damn hard to pass efficiency) and no matter how
far I move my bias aduster (Willwood jobbie) I can't lock the rears (I know I don't want them to, but I'd assume I should be able to
adjust them that far!)
I've trial-fitted the cables and it looks like I can approach from the front. Cable route is bendier, but still operates freely throughought
the suspensions range of movement.
