Charlie_Zetec
posted on 2/4/09 at 12:49 PM |
Different Zetec engines?
I'm running an 1800 Zetec lump in my GTS, from a mid '93 Mondeo (I believe) backed up by a letter from Ford with the engine number. Donor
car for most other bits was an early '93 Sierra 2.0i. Aside from the fact this restricts me putting my L-reg private plate on it, I'm
curious about the block itself.
Now doing my research I've come across the different tpes of Zetec block used in 1800's, with 105, 115, and 130bhp. I know the 130bhp
lumps were usid in the Escort GTi's, but what is the difference in lumps? I read that a lot of you put 130 cams into the 115 for a bit of a
power boost, but what other differences are there?
In terms of my engine, does anyone know what power it has, or how to tell? And Can I exchange parts such as cams from higher-spec engines to get a
little more out of it?
Just for reference, I'll be running ZX9R carbs and megajolt, if that makes any difference.
Looking forward to replies!
big_wasa
posted on 2/4/09 at 01:00 PM |
The code on the engine will tell you what car it came from and what spec.
edit
L1E
L1H
L1J 90 PS @ 5500 134 Nm @ 3000 Escort 1.6
L1F
L1J 88 PS @ 5250 138 Nm @ 3500 Mondeo 1.6
(To 05/98)
1.6 Litre Engines (1598cc - Phase 3)
Code Standard Power Standard Torque Vehicle
L1N
L1Q 88 PS @ 5250 138 Nm @ 3000 Mondeo 1.6
(05/98 - 05/01)
1.8 Litre Engines (1796cc - Phase 1 & 2)
RDA 105 PS @ 5500 153 Nm @ 4000 Escort 1.8
RKC 115 PS @ 5500 159 Nm @ 4500 Escort 1.8
RQB 130 PS @ 6250 162 Nm @ 4500 Escort 1.8
XR3i and GTi
RKA
RKB 112 PS @ 5750 158 Nm @ 3750 Mondeo 1.8
(To 05/98)
1.8 Litre Engines (1796cc - Phase 3)
RKF
RKH 115 PS @ 5750 159 Nm @ 4500 Mondeo 1.8
(05/98 On)
EYDA
To
EYDH 115 PS @ 5750 158 Nm @ 3750 Focus 1.8
2.0 Litre Engines (1988cc - Phase 1 & 2)
NGA 132 PS @ 6000 180 Nm @ 4000 Mondeo 2.0
(To 05/98)
2.0 Litre Engines (1989cc - Phase 3)
NGB
NGC 130 PS @ 6000 180 Nm @ 4000 Mondeo 2.0
(05/98 On)
EBBC
EBBD
EDBA
EDBB 125 PS @ 6000 180 Nm @ 4000 Cougar 2.0
EDDA
To
EDDG 135 PS @ 6000 180 Nm @ 4000 Focus 2.0
[Edited on 2/4/09 by big_wasa]
cliftyhanger
posted on 2/4/09 at 03:14 PM |
And I believe that the differences are teh cams (also ecu/throttle body etc on the original engine)
Running carbs and the better cams should give around 150bhp, (depending which RR/tyres/temp etc )
big_wasa
posted on 2/4/09 at 03:24 PM |
About the only differance between the lower and higher powered 1.8 blocks are the under piston oil cooling gets.
You want a set of 2.0 cams to go with your carbs and Mjl and you should see 150bhp+
I wouldnt bother with any of the 130 spec bits as they tend to cost more than there worth.
posted on 2/4/09 at 03:31 PM |
I have used 1.8 silvertops from an Escort and Mondeo, there is a little bit of difference in the blocks, down where you would put the engine mounts in
a RWD car but nothing huge.
Mondeo engines have bigger sumps than Escorts.
I used 2L cams from a Mondeo engine in my Escort 1.8, all silvertop 1.8 & 2.0 cams swap round no problem.
With 2L cams in my 1.8 with ZX9R carbs and Megajolt it had 155bhp (flywheel) on the rollers, 120bhp at the wheels.
Check my blog out...
SWW84
posted on 2/4/09 at 06:32 PM |
We've fitted 2.0 cams to our 1.8 105 (from XR2). Fitted fine, having said that we haven't run it yet though!
