stupott901
posted on 5/4/09 at 06:56 PM |
SVA AND ACEWELL DASH
hi there
just a quick question i have an acewell digi dash are these sva friendly as at a touch of a button you can change the screen from speedo to engine
temp which i understand is an fail
would it be acceptable to cover up the button so it cant be used ?
cheers stu
daniel mason
posted on 5/4/09 at 07:08 PM |
i failed on thursday with a veypor vr2 dash for that exact reason. it was set so speedo came on when turned on but the examiner pushed a button which
removed speedo.and failed me on the spot! i think many people have passed with digidash so it depends on tester. personally i would either disable
buttons or make a bracket so you cant access buttons. you would kick yourself if you left it and it was your only fail!
rgrs
posted on 5/4/09 at 07:13 PM |
i had the same issue with an koso dash, it is a fail for sva, the tester suggested disabling the button for the test by removing it and taping over
the hole.
Basically the dash must display the vehicle speed at all times.
Roger
Gav
posted on 5/4/09 at 07:16 PM |
yep i failed with a digi dash, however after talking to ETB i sent it them and they put new code on so you carnt change the mode, you can still get
into setup mode by pressing both buttons, hopefully the tester wont press both buttons!
stupott901
posted on 5/4/09 at 07:27 PM |
ok thanks guys i will try to cover it up with some sort of bracket
thanks stu
craig1410
posted on 5/4/09 at 10:02 PM |
I passed okay with an Acewell dash. If I am not mistaken, if you turn off the ignition and then turn it back on it will default to the speedo display.
If so then this should be okay I think.
Good luck,
Craig.
Gav
posted on 6/4/09 at 08:13 AM |
craig1410, Its a new ruling that came in about 2/3 months ago, the dash must display the speed and the units(MPH) at all times, so being able to
cahnge the mode and remove these from the dash is a fail.
zoom
posted on 6/4/09 at 10:44 AM |
My dididash2 failed on friday for not showing the units of measurement at all times and all lighting conditions.
This means the led display is not marked MPH and lit for night time.
Interested to hear your solutions ie reprogramming so the buttons dont work
mycar
mybuildsite
craig1410
posted on 6/4/09 at 06:07 PM |
I was asked if it stayed lit at all times and I said yes but I wasn't asked about units or whether it always displays the speed. Looks like I
was a bit lucky...
