Author: Subject: Rear spacers (35 mm!!)
Maradona
posted on 6/4/09 at 08:31 PM Reply With Quote
I build 35 mm rear spacers to my locost, fit very well!!!
Here I post some pics
rear spacer 2
rear spacer 2
rear spacer 6
rear spacer 6
rear spacer 3
rear spacer 3
rear spacer 4
rear spacer 4
[Edited on 6/4/09 by Maradona]
Diego,
The locost builder from Argentina
clairetoo
posted on 6/4/09 at 10:04 PM Reply With Quote
Um......I cant see a spigot for the wheel to sit on ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
Badger_McLetcher
posted on 7/4/09 at 12:36 AM Reply With Quote
There's pictures in his post?!?
If disfunction is a function, then I must be some kind of genius.
trikerneil
posted on 7/4/09 at 04:14 AM Reply With Quote
Good looking job although it would be good to see location spigots on those spacers as clairetoo suggests.
But is a spigot really required?
The alloys on my VW Passat have plastic rings as spacers between the hubs and wheels.
If for argument's sake the wheelbolt holes were all drilled off centre then I would have thought that the leverage that could be applied by the wheel nut tapers would easily crush the plastic and cause the wheel to "run out".
If the spigot was substantial enough to not be deflected then the wheel nuts would only pitch on one part of their taper and bend the studs to suit.
I've actually seen 100mm PCD wheels fitted to 4"PCD hubs using this "feature"
Does that make sense?
So what is actually centralising the wheel?
Neil
ACE Cafe - Just say No.
damajin
posted on 7/4/09 at 07:07 AM Reply With Quote
Looks like a nice job, what are they made from steel or ali?
Don't suppose you fancy knocking up another pair and sticking them in the post to Southampton
D
adithorp
posted on 7/4/09 at 07:30 AM Reply With Quote
A spigot is not essantial. The wheel nuts are tapered and therefore centre the wheel as you do them up. The spigot just makes life easier to put the wheel on espstially when its wheel bolts not studs.
adrian
http://jpsc.org.uk/forum/
Mr Whippy
posted on 7/4/09 at 09:38 AM Reply With Quote
as above I left the plastic center inserts of the bluebirds alloys with no issues. Its not like the plastic could even take any real loads
posted on 7/4/09 at 11:20 AM Reply With Quote
Spigot rings are not designed to take any load, hence they can be made from plastic. The idea is that the wheel is perfectly centred on the hub before the wheel nuts/bolts are tightened.
Taper seats on the bolts/nuts will help to centre the wheel, but will rarely centre it perfectly. If it did manufacturers wouldn't use hub-centric designs.
You can even get special bolts to do this, called "wobble bolts" that have the tapered washer offset. Complete bodge of course, but some people seem happy with bodges.
Maradona
posted on 7/4/09 at 07:48 PM Reply With Quote
D
The spacers are made from steel, don´t weigth so much 1,7 kg (3,9 lbs) each... jeeee, they will survive to an atomic explosion jaaaaaa!!
Diego,
