MkII
posted on 6/4/09 at 09:27 PM |
cross flow valve guides
hi, is it possible to change the valve guide oil seals on a crossflow without taking the head off/ thanks.m.
mark chandler
posted on 6/4/09 at 10:19 PM |
Yes
Rocker cover and valve gear off, plugs out.
Cord down plug hole then turn engine over so the piston jams this up under the valves, you can now remove the collets in situ as the valve cannot
fall, change seal and re- assemble, pull out string and move on to the next one.
Regards Mark
[Edited on 6/4/09 by mark chandler]
Dave-M
posted on 7/4/09 at 10:15 AM |
seals
I have the proper tool if you want to borrow it, will need compressed air 100psi plus.
dave
posted on 7/4/09 at 04:59 PM |
Compressed air adaptot tool is cheap, collet remover replacer tool is more expensive --- Agriemach sell both
Agriemach item numbers PM-D2110 & PM2211
http://www.agriemach.com/product_info.php?products_id=844
http://www.agriemach.com/product_info.php?products_id=813
