Author: Subject: petrol tank hoze leak
jambo
posted on 8/4/09 at 10:12 PM Reply With Quote
i cant get the hoze to seal with a jubilee clip at the petrol tank inlet.
hoze is the type with a coiled wire set within the rubber,has anyone else had this problem with mnr supplied hoze.
omega0684
posted on 8/4/09 at 10:17 PM Reply With Quote
have you tried using a fuel hose clip and not a jubalee clip
[Edited on 8/4/09 by omega0684]
GeorgeM
posted on 8/4/09 at 10:28 PM Reply With Quote
what he said , petrol hose should have proper
hose clamp - not jubilee
GeorgeM
stuart_g
posted on 9/4/09 at 07:50 AM Reply With Quote
If it is the fuel filler hose you are on about which from your description it sounds like I doubt you will get a fuel pipe clip that big. I bought my jubilee's locally and got them just bigger than the hose diameter (50mm) so I didn't have to tighten them much as they do tend to distort and not stay round, perhaps this is your problem. The filler hose should be a tight fit onto the tank inlet and the filler cap aswell.
bassett
posted on 9/4/09 at 12:44 PM Reply With Quote
Mine was tight and still leaked. Make sure if possible you get it between the spirals. Then go a bit tighter till leak stops.
Adam
