Author: Subject: SVA FAIL- NEWCASTLE
Krismc
posted on 17/4/09 at 01:02 PM Reply With Quote
SVA FAIL- NEWCASTLE
I failed at newcastle but most of the items i did while i was there but he had already wrote them on sheet.
1) Steering rack extensions - No lock nut at track rod end (there is one at rack end)
2) OSF top suspension arm is not 2.5mm- Bit of U-Trim to sort
3) Front Mud guards no trim on inside- U Trim again- DONE
4) Rear Reflectors not to 2.5- Dremal and sandpaper
5) Dash lower edge not 19mm
6) Interior panels not 2.5 - U trim - DONE
7) NS body panel effected by exhaust- cut hole bigger
8) Rear suspension Arm Bolt into hub have no spring washers.
9) Rear position of stop lamps 8mm too low - raise ride height
10) Mirrors distorted from vibration - Put Plates on back possibly
..... and the biggy
11) Emmissons should be 0.2 and they are 5.3 (oh fuck)
Havent a clue what to do with emmissions i got ripped off more than enough for the ECU tuning.
Kris.
omega0684
posted on 17/4/09 at 01:04 PM Reply With Quote
good fail there, days work at most, when is the retest?
vinny1275
posted on 17/4/09 at 01:08 PM Reply With Quote
Emissions seem pretty out of whack! Have you got a cat, and if so, was it hot when they did the emissions test?
The rest of the stuff doesn't see too bad, good luck!
Vince
speedyxjs
posted on 17/4/09 at 01:20 PM Reply With Quote
Thats not too bad and at least you've got SVA and not IVA
Good luck with the retest
speedyxjs
Dangle_kt
posted on 17/4/09 at 01:45 PM Reply With Quote
bad news.
All the best getting it sorted.
splitrivet
posted on 17/4/09 at 02:20 PM Reply With Quote
Bugger, thats me failed on Monday then, didnt think youd need trim on the inside of the mudguards, Bob Hope of getting any now.
Bob
[Edited on 17/4/09 by splitrivet]
jambojeef
posted on 17/4/09 at 03:08 PM Reply With Quote
That not too bad Kris!
I found it quite reassuring to have a definitive list of exactly what needed doing - I found its pretty easy to question a lot of what you have done before presenting at SVA.
Sounds like you've got most things covered - as for lights and emissions, Im sure theres a fix.
Could you temporarily fit bigger tyres to get your ride height up? Or longer springs? Springs are quite reasonable from from Rally Design - assuming they do a long enough one.
As for the emissions - Mine was miles out like that intially - turned out to be bad plug leads. Very bad plug leads - I had made up carbon ones with HT lead on a roll from VWP but shouldnt have done so!
What were the full emissions values?
Well done though - thats the hard bit over!
Geoff
posted on 17/4/09 at 03:09 PM Reply With Quote
Finishing line in sight, at last! Not much to do now.
Kriss
posted on 17/4/09 at 03:58 PM Reply With Quote
could you not but some crappy old wings in any condition and mount you r lights to them just for SVA?
Who mounted them, Mr Darby?
good luck on the retest mate
GeorgeM
posted on 17/4/09 at 04:55 PM Reply With Quote
sounds like my emissions - map needed!!
all the rest won't take long
The end is in sight!!!!!!!!!!
GeorgeM
Krismc
posted on 17/4/09 at 05:05 PM Reply With Quote
Yes they where fitted by Mr Darby. That was the only thing i thought he did right- ive also already raised the car 20mm.
Krismc
posted on 17/4/09 at 05:11 PM Reply With Quote
Geoff
Yea cheers for your advise mate, he checked the bias bar at the setting i had guessed and said i had 34- rear 54 front(not sure what that means) he said thats enough for a pass- and allowed me to lock it off with out washers- just nuts and roll pins in either side.
Emmissions i think is way out 5.4cO @ 3000rpm- he tried again and got 3.0 Co @2900rpm and didnt do rest of test.
I seriosly havent a clue what to do with the car for emmisons, But the rest i can sort.
mad_dogpompey
posted on 17/4/09 at 05:31 PM Reply With Quote
man my mot failure list is normally longer than that! nice one! good luck sorting it out!
Winston Todge
posted on 17/4/09 at 05:35 PM Reply With Quote
Doesn't sound too bad to sort Krism!
I've got my test next Wednesday on an early VortX RT...
Just curious on a couple of your fail points!
So there needs to be a lock nut either end of the extension!? I've got one at the track rod end but not on the back of the extension, i.e. rack end... I dont think I'll be able to fit one in with the toe angles I've got... Any piccies by any chance?!
Is that the U section welded into the top arm?
How are you sorting this radius? Pipe lagging or similar?
Is that on the return lip or the carbon look inserts?
Any help'd be appreciated!
Any other tips you'd look out for when SVAing a VortX?
Ta!
Chris.
scottc
posted on 17/4/09 at 06:05 PM Reply With Quote
Thats not too bad mate.
There's not much work there at all. Especially considering you did most of it there.
I should be back in Newcastle soon for a week or two, I'm expecting a ride!!
Krismc
posted on 17/4/09 at 08:08 PM Reply With Quote
Ta!
Chris.
1) Yes nuts on both sides like you say- he said although the lock nut fitted , locks the rack to the extension bar, it doesnt lock the bar to the rod end, therefore the hole extension and rack can turn free as one piece.
2) yes the 2 bits of U shaped metal that the bolt goes through, i believe the never chassis they are smaller and further back.
5) Im not sure as ill have to permantly attach to the dash- glue or holes/bolts required he said thats the only way.
6) Return lips
jambojeef
posted on 18/4/09 at 08:13 AM Reply With Quote
Re: Rack extensions
I got round the nuts either side of the extension issue by loctite-ing a length of 10.9 studding between the the track rod end and the extension and taking photos of what id done to show Mr SVA.
He was 'happy' with that but its on my ever growing list of stuff to re-do.
Would like to make something a little less over-engineered at some point......
Geoff
Krismc
posted on 18/4/09 at 10:25 AM Reply With Quote
IM sure ive loctited mine in but he said not good enough with no proof, ill remove and see if i could add a nut, if not loctite and pics it is.
cheers again geoff for info on brakes. he tested them how i had set it up, he was happy and let me pin them there and then.
