Author: Subject: Crossflow package complete
clairetoo
posted on 18/4/09 at 07:52 PM Reply With Quote
For sale soon - a complete crossflow set-up , coming out of a Fury (to be replaced with a V6.....)
Spec is -
711M block , decked 30 thou , lightened/balanced , +90 pistons , big valve ported head , lightened flywheel . Kent 244 cam , steel rocker post's and double valve springs . High volume/high pressure oil pump , shortened/baffled sump .
Type 9 gearbox with ally bell housing , properly welded cable clutch conversion .
Kawa Gpz 1100 throttle bodies , re-spaced on a one-off ally manifold with billet fuel rail and Webcon TPS , carbon bellmouths and backplate with Pipercross PX filter .
Billet magnesium multi-v pulley set with one-off 36-1 trigger wheel .
Omex 400 ECU with all sensors and wiring .
This is a complete running car at the moment - I built it and it drives really nice , power from tickover till you bottle it and change up - the last rolling road set-up showed 135 BHP (which I think was a little pessimistic)
It will be coming out soon , and I would rather sell as a complete lot - asking for £800 OVNO .
Its cuz I is blond , innit
Claire xx
Will weld for food......
Staple balls
posted on 18/4/09 at 07:56 PM Reply With Quote
Very, Very tempted.
clairetoo
posted on 18/4/09 at 08:07 PM Reply With Quote
Oh - and forgot to add the head has unleaded exhaust seats and will include the Ford coilpack and leads - ready to run .
[Edited on 18/4/09 by clairetoo]
Claire xx
Staple balls
posted on 18/4/09 at 08:12 PM Reply With Quote
I hate you
Question is, is it worth paying the pennies to replace the crapped out 1.6 pinto I have?
posted on 19/4/09 at 06:12 AM Reply With Quote
I might be biased as I have a similar spec engine in my car but that sounds like a good deal for someone.
posted on 19/4/09 at 06:57 AM Reply With Quote
I might also be biased - but a well-tuned x-flow does make a LOVELY noise when pushed hard!
Confused but excited.
posted on 19/4/09 at 03:53 PM Reply With Quote
It cost me £220 just to get unleaded seats, new guides and valves put in and that was half what burton Power quoted me.
If I was just starting to build, I'd rip someone's arm off at that price.
arrow-engineering
posted on 19/4/09 at 04:45 PM Reply With Quote
engine
can you ring me on 07891 604755 or send me your number and ill give you a ring. thanks
clairetoo
posted on 19/4/09 at 06:29 PM Reply With Quote
Now sold to Staple Balls
Claire xx
Staple balls
posted on 19/4/09 at 06:52 PM Reply With Quote
