afj
posted on 21/4/09 at 05:54 PM |
carbon mods skinning kit
has anybody used the carbonmods carbon fibre skinning kit that they sell, is it anygood
eerrrrrrrrrrrrrrrr
locoR1
posted on 21/4/09 at 06:17 PM |
haven't used but I came across the video on youtube when doing some research for my latest project makes it look quite easy but i bet its not
that simple!
Not that you would tell me but i will ask anyway,What you planing on skinning?
http://www.youtube.com/watch?v=6rTWaV1imzs
Check out my CB500T Cafe Racer build diary
afj
posted on 21/4/09 at 07:00 PM |
just my standard airbox
eerrrrrrrrrrrrrrrr
Steve Hignett
posted on 21/4/09 at 07:27 PM |
I was there when Paul was putting the kit together and the resins and activators etc that are in the kit have been specifically developed (for him)
for that kit - ie they were developed for the home user.
The kit is pretty complete - you won't really want for much else apart from the scales and heat gun that is described anyway.
With regard to most things carbon fibre, Paul (the guy in the vid), could make pretty much anything look simple, but he has tried his best to see it
from a first timers point of view and if you give him a call he will run through everything you need to know just in case anything is unclear from the
video.
Having said all that, there is a definite skill to working with composites, and although you should be able to turn out a fine skin on something as
simple as an airbox, if you wanted to start making quite complex shapes and for them to look good upon release, then you will have to put in a bit of
practice to ensure a perfect part!!!
ps. Post up some WIP pics of you skinning it up!
ETA - CarbonMods Skinning Kit!
[Edited on 21/4/09 by Steve Hignett]
greggors84
posted on 21/4/09 at 10:56 PM |
What is the black primer they use in the kit? It says its to give a black background for the carbon and for it to bond to but what actually is it? A
type of resin?
Chris
The Magnificent 7!
StevieB
posted on 22/4/09 at 03:46 PM |
Yeah, it gets mixed with a bit of hardener.
If you look on the website, as well as the starter kit you can buy the resins and matting in larger quantities.
I going to give it a go on some of the plastic trim on my elise to give it a bit of a refresh and some appeal before I sell it.
