Author: Subject: Arrgh how are you meant to decide between BEC and CEC?
novacaine
posted on 22/4/09 at 06:37 AM Reply With Quote
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
flak monkey
posted on 22/4/09 at 06:41 AM Reply With Quote
Depends what you want.
If you want a car for longish journeys which is easy to drive and reliable go for a car engine.
If you want a track day car for short runs which is hard work to drive build a bike engined one.
Having driven both, and the sort of driving I do, I know which I prefer
Sera
http://www.motosera.com
iank
posted on 22/4/09 at 06:51 AM Reply With Quote
On top of Flak's excellent guide.
Cost - BEC's tend to cost a little more than CEC's installed - especially now IVA requires a reverse of some kind.
How much power do you want? Once above 175-200bhp CEC's rule, up to that BEC's are in their sweetpoint. How much power you can usefully use in a 7 is debatable of course.
Noise - BEC's are marmite here. Do you love the sound of F1, Touring cars or NASCAR?
The only real answer is down to you, everyone else is just spouting their own personal prejudices.
Anonymous
Antnicuk
posted on 22/4/09 at 06:58 AM Reply With Quote
in answer to your question, test drive one of each,
but don't forget the alternative ........ REC!
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
speedyxjs
posted on 22/4/09 at 07:06 AM Reply With Quote
Or EEC.
An electric seven has been built before and was pretty quick!
omega0684
posted on 22/4/09 at 08:24 AM Reply With Quote
you get the bike engine and then through it out the window!
the you get a car engine
adithorp
posted on 22/4/09 at 10:20 AM Reply With Quote
Go to Stoneleigh and beg a ride in a BEC and then decide thats what you want after about 10 seconds. Sit back and ejoy the rest of the ride.
adrian
http://jpsc.org.uk/forum/
