Author: Subject: Need a paddleshift!
blueskate
posted on 22/4/09 at 03:07 PM Reply With Quote
Need a paddleshift!
Hi everyone,
Anyone know where i can get a decent paddleshift setup for my MK?
Semper Paratus!
Pdlewis
posted on 22/4/09 at 03:43 PM Reply With Quote
AB performance not the cheapest but the service and product is exceptionally good the fitting etc is all adjustable and custom machines for you along with the modular construction been much better than alot of the one peice jobbies
cant recommend them enough
Build Photo Album
Updated 05/02/2009
INDY BIRD
posted on 22/4/09 at 05:57 PM Reply With Quote
where abouts in essex are you??
i have fitted 2 kits before may be able to help out or recommend someone to make it/fit it aswell
pic attached on mk i did stainless cow horn paddles
cheers
blueskate
posted on 22/4/09 at 07:48 PM Reply With Quote
Hi all,
Thanks for the reply's
PDlewis : Yep seen these kits on ebay. The look very comprehensive, Definately will consider this.
Indybird : I'm in Dagenham .. but the car is at MK at present, they are having trouble locating a kit. Apparently Pathfinder has gone AWOL lol. Do you supply the kits? Or just fit them?
thanks
Semper Paratus!
INDY BIRD
posted on 22/4/09 at 07:59 PM Reply With Quote
probably could get one for you,
i have supplied mk with 2 kits in the past to go to spain speak to baz and he knows me (sean that is)
let me know then i will find out how much for you generally just supply the cow horn and bracket to fix to sierra colum shroud the rest just made up from straight ali rod or m8 rod they can supply,
cheers
sean
failing that i can put you in touch with a friend who if you take the car to him near stansted essex will make it to fit the car not too expensive will also get cost on that for you if you like u2u me
[Edited on 22/4/09 by INDY BIRD]
INDY BIRD
posted on 22/4/09 at 08:24 PM Reply With Quote
Blueskate
u2u sent
j-k
posted on 22/4/09 at 08:55 PM Reply With Quote
i am interested in purchasing a paddle shift system for my MK, but would want to retain the sierra switchgear.
INDYBIRD...is this something you can help me with also?
jon
INDY BIRD
posted on 22/4/09 at 09:36 PM Reply With Quote
Hi Jon
yep can be done thats what i did as you can see from the pics,
now i dont have as much time as got 2 projects on the go but will speak to my friend who makes them, if you just want a paddle shift,
best service though is,
you take the car to him and he will make the kit to fit the car if interested u2u me and i will send details based in essex
cheers
sean
matt.c
posted on 22/4/09 at 10:15 PM Reply With Quote
Pathfinder sell his paddleshifts on ebay.
blueskate
posted on 23/4/09 at 08:48 AM Reply With Quote
Checked his ebay and he says he is not selling any more for a while
Semper Paratus!
j-k
posted on 24/4/09 at 06:15 PM Reply With Quote
INDY BIRD...
Incoming U2U...
