cd.thomson
posted on 27/4/09 at 01:41 PM |
wiring my VR Sensor
I've just been searching and I understand there's some confusion about which wire on the ford VR sensor goes to which pin on the EDIS. Does
anyone know, id rather solder it right first time .
Secondly..what is this forcefield being emitted by pin 7?
Craig
posted on 27/4/09 at 01:58 PM |
7 is a grounded wire that shields the VR wires from noise, as it says somewhere as well the earthing should only be at one end.
[Edited on 27/4/09 by coozer]
Yes you would rather expect one end of the screen to be earthed...
Sporty
posted on 27/4/09 at 02:00 PM |
The polarity of the VR sensor is shown in the Mondeo Haynes manual, don't know now but will have a look tonight if someone hasn't already
given you the answer.
and as Coozer says for the force field.
Ian
dhutch
posted on 27/4/09 at 02:01 PM |
But equally, usually, only one end. So as not to create and earth loop.
posted on 27/4/09 at 02:11 PM |
Absolutely, been there done that, heard the horrible hummy buzzy noise....
cd.thomson
posted on 27/4/09 at 02:12 PM |
So its just a normal bit of wire that comes from pin 7, wraps round and round the VR sensor wires so its like a coiled telephone wire then gets
screwed into the chassis at the other end?
Craig
Slater
posted on 27/4/09 at 02:25 PM |
You need special shielded cable. I bought some 2 core shielded cable from maplins. The sheild bit is like the outer woven copper wires you find on an
TV ariel leads.
posted on 27/4/09 at 02:34 PM |
Better to get the original wire of a Mondeo or the like.
rsmith95uk
posted on 27/4/09 at 04:11 PM |
sorry to hi-jack the thread, but what is the VR sensor being talked about here?
I am in the process of fitting megajolt to my pinto, & the schematic that I am working to has no attachments to pin 7 shown!
Ray
OK, mis read the post - but the comment on pin 7 stands - is this required?
[Edited on 27/4/09 by rsmith95uk]
clairetoo
posted on 27/4/09 at 05:27 PM |
Ray
Yep - definitely - you will get a lot of `noise` without it
Its cuz I is blond , innit
Claire xx
Will weld for food......
paulf
posted on 27/4/09 at 08:07 PM |
If you get an Edis plug the wiring is all conected at the plug end.You will find the shielded cable for the VR and PIP SAW leads are all connected
together and earthed via one connection at pin 9 on the Edis end.The VR connections will be correct if you use the original wiring and match the
coulors otherwise just make a temporary connection with tape to test it.
Paul
[Edited on 27/4/09 by paulf]
flak monkey
posted on 28/4/09 at 05:57 AM |
Any help?
[Edited on 28/4/09 by flak monkey]
Sera
http://www.motosera.com
cd.thomson
posted on 28/4/09 at 07:55 AM |
Cheers everybody, thats everything I need I think..unless anybody has some spare shielded cable.
All I can find are shielded TV cables
Craig
paulf
posted on 28/4/09 at 09:37 PM |
You could get enough from a fiesta, escort or early mondeo with the edis module.If you already have a plug with short leads then maplins sell some
suitable shielded audio type cable, I have just repaired my sons electric guitar lead and that is very good quality shielded cable.
Paul.
cd.thomson
posted on 29/4/09 at 09:47 AM |
Thanks paul, I guess you used this stuff:
http://www.maplin.co.uk/Module.aspx?ModuleNo=125
thought I'd post it for other people who might be looking.
Does anyone have a picture of this tiny bit of wiring? I'm not sure how dense the shielding cable has to be around the VR sensor wires - should
it form a physical barrier (wrapped tightly round and round then taped over with electrical tape) or does it just need to be wazzed round it a few
cursory times and electrical field wizardry does the rest?
Craig
paulf
posted on 29/4/09 at 08:16 PM |
Yes that would do the job,or if your going to stonleigh on sunday I can bring you some that I have spare , I usually pick up oddments at work if I see
any lying around.
Paul.
dhutch
posted on 16/6/09 at 05:56 PM |
Just in the process of wiring up my own MJLT loom and have raised the issue of VR sensor polarity on the autosportlabs forum and an amendment to the
installation guide is going to be carried out to add the information.
Also, i cant help but notice that the EDIS plug i have does not actaully have a sheilded cable going to the VR. The cable ive used (scrouged of a
vauxhall cav along with the tps and cable) is shealded but im tempted to just leave the sheilding disconected for now...
Daniel
