Author: Subject: A few bits FS for Stoneleigh
twybrow
posted on 30/4/09 at 07:17 PM Reply With Quote
I am going to Stoneleigh on the Monday, and I have the following for sale:
1. Coolant in-line temperature sensor adaptor. 30mm with 1/8npt sensor thread. £10 Sold to Dogwood
2. Triumph Daytona silencer - inlet turned to suit a car. £15
3. Expansion tank with clear silicone hose, complete with bracket. New and never used. £7
4. Stuart-Taylor interior panels (tunnel sides and top). Trial fitted only. Some surface scratches, but nothing that wont polish out. £25 Sold to Neil2004
5. Hella stop/tail & indicator rear lights. New in the box. £20
6. Rear view mirror (suction). No good for my SVA, but plenty have used 'em. Modified slightly to allow more movement. £3
7. Seat runners (both sides). Bought off here as Metro runners, but not sure they are...? Look like they would need cutting/welding for a 7. Lovely condition. £10
8. Side mirrors, with repeaters. I think it is an M10 fine thread. New in the box (box is a bit tired). £10
9. Carbon fibre dash. Cut and drilled to fit onto a Velocity dash with Sierra cowl, but would fit others as well. Not drilled for any gauges. Rough dimensions are 42" wide at the widest point, and 8 3/4" height to the main part of the dash. One light surface scratch (will polish out no problem) and a few fingerprints! No radius to bottom edge, so would need padding, or post-sva. £60
Offers welcome....
[Edited on 30/4/09 by twybrow]
[Edited on 5/5/09 by twybrow]
dogwood
posted on 30/4/09 at 07:25 PM Reply With Quote
I'll take the temp sender adapter pipe
Could be interested in the wing mirrors as well
Cheers David
[Edited on 30/4/09 by dogwood]
FREE THE ROADSTER ONE…!!
twybrow
posted on 4/5/09 at 01:04 PM Reply With Quote
Everything apart from the temperature sender still available... I'm open to offers if my asking prices are a little off!
skippad
posted on 5/5/09 at 12:05 PM Reply With Quote
I'll have mirrors and runners...
inc p+p?
twybrow
posted on 5/5/09 at 08:19 PM Reply With Quote
The runners are pretty heavy, so I'll stick 'em on the scales and let you know.
