dh2909
posted on 3/5/09 at 04:36 PM |
Fuel Line + cycle wings Q
I was jst wondering if i will have to clip more of the fuel line to the chassi as it runs up thru the fuel filter and into the engine to pass IVA?.
See pics.
I was also wondering as i hav got 205 width tyres will the standard Indy cycle wings be wide enough or will i have to invest in some wider
1's?
Thanks Dave
dead sierra
posted on 3/5/09 at 06:46 PM |
I have standard indy cycle wings and 205 tyres and they fit fine.
I would say that if the fuel filter moves excessively then you would probably need more support.
It wouldn't hurt to have more support and putting it in now will be a lot easier than when its all built up.
Humbug
posted on 3/5/09 at 06:51 PM |
Could you make up a little bracket out of ali strip to give the filter a bit of support independent of the hose?
eccsmk
posted on 3/5/09 at 07:14 PM |
as above
a small strip of alu bent rount the filter and fixed to the side would support the filter and maybe a P-clip for the rubber hose rather than a cable
tie ??
dh2909
posted on 4/5/09 at 12:27 PM |
thnaks for the help! i have some alluminium i could easily make into a bracket so shall do tht now rather than if it needs it l8r!
cheers for the help!
dave
Guinness
posted on 4/5/09 at 06:09 PM |
Just a word of consideration.
Think about replacing that fuel filter once the car is built. You will have no access from underneath, nor from the sides, nor from above. The only
way in will be past the engine.
Mike (a man who has loads of service items located in inaccessible places!)
sickbag
posted on 4/5/09 at 07:51 PM |
Another thing to consider if the motor is fuel injected is will the filter withstand the high pressure from the pump?
Has anyone successfully used one of these filters on the high-pressure side?
Finally back on the job!
