Author: Subject: Sierra stripping
Jezzer99
posted on 3/5/09 at 09:35 PM Reply With Quote
Sierra stripping
Any recommendations on the best way to strip a Sierra - i.e. where to start and where to finish and in what order?
big_wasa
posted on 3/5/09 at 09:37 PM Reply With Quote
unless you have a big yard with plenty of space leave the axles and wheels on untill last so you can move it around.
Miks15
posted on 3/5/09 at 09:51 PM Reply With Quote
Id say whack the engine out, then bits you want from the inside, then turn her over for the running gear
Bigheppy
posted on 3/5/09 at 10:03 PM Reply With Quote
Like this
stripping sierra
stripping sierra
using an air chisel if you have limited space.
stripping sierra 2
stripping sierra 2
stripping sierra 3
stripping sierra 3
MakeEverything
posted on 4/5/09 at 07:39 AM Reply With Quote
Dynamite?
Kindest Regards,
Richard.
RichieW
posted on 4/5/09 at 10:56 AM Reply With Quote
Don't forget to undo the rear hub nuts while the rear axle is still in one piece on the car. They are torqued very high. 200 and something foot pounds.You need to undo them on the car so you have something to turn against. You will need a scaffold pole or similar.
Jezzer99
posted on 4/5/09 at 11:05 AM Reply With Quote
So will an air impact wrench with the appropriate size socket not shift the hub nuts when they're on the car?
austin man
posted on 4/5/09 at 11:06 AM Reply With Quote
or if youve forgotten to remove the nuts an air chisel or impact gun. Classic mistake to make also recomment the same for the font hubs a lot easier to slacken when on the car.
RichieW
posted on 4/5/09 at 12:07 PM Reply With Quote
Haynes says rear hub nut is 221 ft/lbs, Left hand nut has a left hand thread.
If you have top notch air gear then it may shift but many people have resorted to big levers. Remember that the nut hasn't shifted off the thread for probably 20 years so may be well stuck. I think the hub nut is 41mm across so you may have to go out an buy the appropriate socket. If you do a forum search you will find this has been covered many times before.
Have fun
serieslandy
posted on 4/5/09 at 12:25 PM Reply With Quote
I used an impact wrench on mine and it uses a 41mm impact socket (came off ebay) However remember that the passanger side is a CLOCKWISE thread (opposite).
I started with wiring, other bits then engine and running gear when it was outside.
I did have the help of a forklift to lift engine out and shell up and down.
stevegough
posted on 6/5/09 at 07:56 AM Reply With Quote
no further advice as far as the order of stripping goes, but don't underestimate how much there is! I have a few photos saved under the 'donor' file in my photoarchive which gives you a good idea. Also, I stripped the car totally, and cut up the shell as the scrapyards aren't interested in collecting the empty shell.
A word of warning - be careful if you do this - plan how to cut it first, the bits spring up / off / down in some surprising ways - you can get some very dangerous kick backs off the angry grinder !!!
On the other hand, it is good fun !
Good luck!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
posted on 6/5/09 at 08:18 AM Reply With Quote
Are you using ALL the Sierra? I'm looking for a Sierra being stripped locally to nick the wiring loom from. Where are you?
