<<  1    2  >>
Author: Subject: Fuel tank breather?
Northy
posted on 28/2/04 at 12:49 PM Reply With Quote
Fuel tank breather?
What do people do with the breather pipe from the fuel tank? Does it need a one way valve? Or just a pipe to let it breath to air?
Graham
theconrodkid
posted on 28/2/04 at 12:55 PM Reply With Quote
best to have a one way valve,my tank used to empty over a week in the summer with evaperation
who cares who wins
pass the pork pies
jonti
posted on 28/2/04 at 01:58 PM Reply With Quote
Don't you need a two way valve to allow for expansion on a hot day ?
OFROK
Surrey Dave
posted on 28/2/04 at 01:59 PM Reply With Quote
Isn't a 2 way valve , just an open breather pipe?
theconrodkid
posted on 28/2/04 at 02:39 PM Reply With Quote
hold on dave ill get my calculater out
who cares who wins
pass the pork pies
CairB
posted on 28/2/04 at 05:45 PM Reply With Quote
Northy,
I used the valve off the Sierra filler assembly. A vent pipe was connected to the top of the fuel tank then up in a loop as high as possible then down to the Sierra valve then to atmosphere. From memory, I think that the valve would shut off when upside down but otherwise give free breathing both ways.
I haven't noticed any problems...but I haven't tested it by rolling the car.
Surrey Dave,
[Quote]
[Quote]
Not necessarily. It could be implemented using 2 check valves in parallel facing opposite ways. This would mean that it would seal in both directions unless the cracking pressure was exceeded in either direction.
Colin
Northy
posted on 29/2/04 at 08:53 AM Reply With Quote
Now I'm really confused
Is there any requirement for SVA?
Graham
Surrey Dave
posted on 2/3/04 at 10:02 PM Reply With Quote
You what!!
Northy
posted on 2/3/04 at 10:07 PM Reply With Quote
Dave I was just about to reply to this thread!
I phoned Beverly to ask the SVA guy there, and he says he's not bothered at all. Wouldn't even be checked.
So, am I best off fitting a one way valve to avoid evaperation? If so where can I get a Locost one? I'm not prepared to pay Demon Twats prices
Graham
wicket
posted on 2/3/04 at 10:26 PM Reply With Quote
Graham
Here's another source
http://www.bsr-aerotek.com/fuel18.htm
Eric
Jon Ison
posted on 2/3/04 at 10:28 PM Reply With Quote
valve out of a push bike, cheap as chips.
Northy
posted on 2/3/04 at 10:35 PM Reply With Quote
Push bike? Are you serious? What valve?
Graham
posted on 2/3/04 at 10:42 PM Reply With Quote
inner tube one i guess. makes sense actually!
Northy
posted on 2/3/04 at 10:57 PM Reply With Quote
Not to me!
Can you explain how you'd use it?
Graham
Jon Ison
posted on 2/3/04 at 10:59 PM Reply With Quote
yup inner tube valve, works just fine, even sufficient to get by scrutineering for off road events...........
Northy
posted on 2/3/04 at 11:02 PM Reply With Quote
Which way round would you fit it? Sorry if I'm being thick, just not understanding how it would work!
Graham
Jon Ison
posted on 2/3/04 at 11:13 PM Reply With Quote
to allow air into tank but nothing out, they are a very simple 1 way valve which is what your looking for, have a flexible tube from your tank breather with the valve in the end of it...........
greggors84
posted on 2/3/04 at 11:17 PM Reply With Quote
Would you use the thread on the bicycle valve or just attach it another way?
Chris
The Magnificent 7!
Surrey Dave
posted on 2/3/04 at 11:41 PM Reply With Quote
I like it 'Locost' and simple , just push it into some flexible pipe and crimp or use jubilee clip.
Will the vacuum in the tank be enough to open the valve?
If I grind to a halt with fuel starvation I'll no who to blame , Mr Ison
All the local motorcyclists will be please that i'm not dropping fuel at roundabouts then!
Mark Allanson
I would have thought that cutting out the valve from the inner tube and fitting it into some 8MM ID Petrol suitable rubber pipe, other end fitted to the tank or filler neck
madforfishing
posted on 2/3/04 at 11:50 PM Reply With Quote
You're too fast Mark.
That's exactly what I have done about 2 nights ago.
I thought I was being SooooooooooooO
clever.
Damn, you guys are good. (or eves-dropping)
I'll never conquer the world at this rate.
Off Topic: ref evesdropping etc...
Do you think Claire Short signed the Official Secrets Act in her capacities as a MP ?
If so why isn't she banged up in HMP Holloway ? ( or the Tower) ?
greggors84
posted on 3/3/04 at 02:43 AM Reply With Quote
She probably knows alot more, that she would tell if they banged her up!
Chris
The Magnificent 7!
posted on 3/3/04 at 09:38 AM Reply With Quote
anyway, would you want to bang her up in the tower?!?!?!?
but yeah, she knows more, should probably be silenced anyway. she's SO naive...
jonti
posted on 5/3/04 at 06:29 PM Reply With Quote
Think this has been covered above but my ten pennoth for what it's worth
On the face of it yes but not if both "ways" have a spring loaded valve. Air can be pushed and sucked through but liquid not under pressure ie fuel slop will not pass. You do need two pipes for this to work though.
However, from what's been said the pressurisation of the tank is not an issue so as long as air can get in and fuel can't get out it's seems like you're ok.
Bike vave is a good idea.. I like that
[Edited on 5/3/04 by jonti]
OFROK
Jon Ison
posted on 5/3/04 at 06:42 PM Reply With Quote
bike valve = locost.
they do work fine too, just as good as a £XX version.....
Bit like the USA inventing that pen that would write in space/zero gravity and spending millions$$ on it,
wot did the Russians do? took a locost pencil
<<  1    2  >>
