paulbeyer
posted on 16/5/09 at 02:33 PM |
OT Corsa Tintop Bogging Down
My Son has a MY2000 Corsa B 1.0L X10XE Isuzu 3 cylinder engine that is bogging down under acceleration. We have fitted a new MAF sensor, Idle control
stepper motor and throttle position switch but it is still playing up.
Does anyone have experience with this type of engine and have any idea what could be causing the problem?
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
Z20let Corsa
posted on 16/5/09 at 03:57 PM |
you sure its not just the size of the engine just joking. is it just on the bottom end power its bogging or top end or all the way through??? ive
worked a lot with all sizes of engine in the corsa so may be able to help.
posted on 16/5/09 at 04:01 PM |
Whenever my daughter's Corsa acted up it was always the EGR valve. I took it out and cleaned it with brake cleaner and it was fine till it stuck
again.
mistergrumpy
posted on 16/5/09 at 06:06 PM |
I've had the EGR problem on my dads Corsa which is a diesel and cleaning it worked wonders. The other thing which I believe is common across the
model and also on the Alfa i used to have was the air flow meter. The plastic thing that has a plug off it and sits in the air intake.
posted on 16/5/09 at 06:31 PM |
mine keeps on doing that, i had put it down to spark plugs. Might have to check the EGR valve!
Er, what is it anyway?
clairetoo
posted on 16/5/09 at 07:00 PM |
My `93 1.4 has been doing that off and on for about a year and a half.........
I might have a look at it...........but then again , I might not
Its cuz I is blond , innit
Claire xx
Will weld for food......
mediabloke
posted on 16/5/09 at 08:58 PM |
again.
^^^What he said. Slightly OT, but it's also a stock fault on the previous Ford Ka 1.3. £3 worth of brake cleaner's far better than
£££'s worth of a dealer's time! ;-)
paulbeyer
posted on 16/5/09 at 09:56 PM |
It bogs down as soon as you try and accelerate normally. If you are really gentle with the loud pedal it will build up revs gradually but has a
serious lack of power (yeah I know it's only 1 litre). Will try cleaning out the EDR tomorrow and see if that helps.
paulbeyer
posted on 16/5/09 at 09:57 PM |
serious lack of power (yeah I know it's only 1 litre). Will try cleaning out the EGR tomorrow and see if that helps.
mediabloke
posted on 16/5/09 at 10:20 PM |
Sorry - second thought (got a bit confused for a mo). Is there an idle control valve on the 1.0l Corsa?
It was the ICV on the Ka (not the EGR valve) and happened particularly after a motorway run: dip the clutch, revs rise; press the loud pedal, the revs
drop and the engine stalls. Sound familiar?
Removed the ICV, sprayed it with brake cleaner - all good.
posted on 16/5/09 at 11:09 PM |
It's the thing on top of the inlet manifold held on with two torx screws. It opens up and allows exhaust gas to be recirculated cleaning it up
but when it sticks open the car runs weak and will not pull or is reluctant to start and tick over.
paulbeyer
posted on 17/5/09 at 12:20 AM |
Yup, put a brand new one on this morning - It didn't help.
