dr-fastlane
posted on 22/5/09 at 07:31 PM |
Project RW1 update
Last winter I bought me a ac/dc Tig welder en started to modify the standard EFI inlet manifold.
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
dr-fastlane
Finished manifold
Howlor
posted on 22/5/09 at 07:46 PM |
Nice work there, I really like the louvres and the tooling.
The seats are superb.
dr-fastlane
posted on 22/5/09 at 07:48 PM |
With the lowered manifold it became time to skip the old bonnet scoop en build a new flat bonnet with some nice louvers. Here is the tool that I made
to press the louvers.
dr-fastlane
Bottom louvre former
dr-fastlane
Upper louvre former
dr-fastlane
posted on 22/5/09 at 07:49 PM |
The firts stap was to cut the slots in the bonnet because the louvre tool would not cut it itself. I had to cut first small slots with a 1mm grinding
disc to get access for the saw to get in.
dr-fastlane
posted on 22/5/09 at 07:50 PM |
After smoothen the slot the used the louvre tool to press the louvress with a piece of wood an a hammer hitting on top of the upper louvre former.
After all louvers where done it needed a little attention with some sandpaper.
The finished bonnet is made out of 1,5 mm aluminium plate.
dr-fastlane
posted on 22/5/09 at 07:51 PM |
Because I was not happy with the old steel fuel tank, made a new one out of 3 mm aluminium plate.
dr-fastlane
Intank swirlpot to fit the slightly modified Sierra Fuel pump/sender.
dr-fastlane
posted on 22/5/09 at 07:52 PM |
The next thing to do is building some new seats that will fit lower into the car.
prawnabie
posted on 22/5/09 at 08:07 PM |
Some nice work there!
Mave
posted on 22/5/09 at 08:20 PM |
Wow, very nicely done! I'd like to borrow your louvre tool one day......
Groet,
Marcel
dr-fastlane
posted on 22/5/09 at 08:39 PM |
I’m very pleased with it myself. It was difficult to get the slots ( thank you drhunter) sawed out straight, with the tool pressing the louvers is
the eaisiest part.
Marcel: That’s a deal, give me a yell when you need it
[Edited on 30/5/09 by dr-fastlane]
drhunter
posted on 29/5/09 at 10:59 PM |
quote: It was difficult to get the sluts sawed out straight,
sorry but hehe that made me giggle.
Great work on the bonnet!
dr-fastlane
posted on 30/5/09 at 07:41 AM |
That would make it a complete different project..
changed it, thank you Drhunter
dr-fastlane
posted on 8/7/09 at 05:55 PM |
Little update here. The seats are finished and in the car. Later on they will be covered with some fine
leather…
dr-fastlane
posted on 8/7/09 at 05:56 PM |
And in the car.
iank
posted on 8/7/09 at 06:01 PM |
Seats look very good in the car.
Anonymous
t.j.
posted on 8/7/09 at 08:02 PM |
That's looking great!
Why did you choose the Sierra pump?
My idea is taking an external Opel Calibra pump. The presure should be equal.
but maybe your right i must have a fuel-idicator.... so...
I want also a Tig which can handle alu...
But budget...always the budget...
Don't make it too beautifull or mine will look more ugly
grtz
dr-fastlane
posted on 9/7/09 at 07:57 PM |
Yeah, they do and sit also reasonable comfortabel.
grtz
The first idea was also to use a external fuel pump. But then I needed a separate fuel sender and gauge. With that also had to change the other gauges
to have it all the same. Because I used the sierra ones. That would be to expensive. Found a easy way to fit the old sierra bump into the tank. So,
have kept it as with the old steel type tank.
Come on!! That build of you gone be a splendid ride to!! Nothing can beat those Donkervoort body parts that you have
[Edited on 9/7/09 by dr-fastlane]
dr-fastlane
posted on 14/7/09 at 06:41 PM |
Finished the new exhaust shield last weekend. Here some pictures:
dr-fastlane
posted on 14/7/09 at 06:42 PM |
And another one
posted on 14/7/09 at 06:48 PM |
Nice work!
One question - what angle have you set your windscreen? It looks a bit steeper than usual - quite like it that way.
dr-fastlane
posted on 14/7/09 at 07:45 PM |
quote: Originally posted by David Jenkins
Nice work!
