Author: Subject: diff /prop spacer..
robbydee
posted on 24/5/09 at 10:05 PM Reply With Quote
diff /prop spacer..
I have had to replace the rear gearbox oil seal 3 times now, after some tugging i get alot of movement in the front uj joint on the prop..... I am thinking the prop is actually a bit short.....
can you get prop spacers? looking for one around 20mm are they safe to use? provided they are steel etc..
big_wasa
posted on 24/5/09 at 10:08 PM Reply With Quote
I have a spacer that was made by a prop company. Its to go from a tri-pod to standard uj but its still a spacer
liam.mccaffrey
posted on 24/5/09 at 10:23 PM Reply With Quote
chrisf's locost has ali driveshaft spacers @ maybe 20mm? no problem imho
[Edited on 24/5/09 by liam.mccaffrey]
Build Blog
Build Photo Album
robbydee
posted on 24/5/09 at 10:25 PM Reply With Quote
any idea when i get one?
Any body do them off the shelf to speak..
flak monkey
posted on 25/5/09 at 07:54 AM Reply With Quote
I made one for my prop which was about 20mm thick iirc. Made out of aluminium. The most important thing is that the spigot and recess which centralise the prop are concentric.
Sera
http://www.motosera.com
robbydee
posted on 25/5/09 at 09:06 AM Reply With Quote
Do you have any technical pictures?
Size pcd hole sizes etc?
Photo??
