robbydee
posted on 27/5/09 at 08:13 PM |
prop too short?
This is a pic of my prop, is it too short not engaging properly? causing too much play?
total prop length is 920mm
diff flange to gearbox casing is 875mm
So is this actually too short?
jacko
posted on 27/5/09 at 08:19 PM |
yes it looks it to me mine only has about 20mm / 25mm gap when fitted
Jacko
robbydee
posted on 27/5/09 at 08:24 PM |
I have actually broken 1 gearbox casing and replaced a few rear seals so beginnig to think of causes...
blakep82
posted on 27/5/09 at 08:32 PM |
eek, i'm getting worried now, i got my prop made without my gearbox being in the right place... should still stil better than yours though.
i would have thought the worst result would be the splines stripping from the output shaft on the gearbox.
but it could do with a better fit. i recommend dunning and fairbank. they came in a good £50 cheaper than everyone else for my prop
or would it be possible to get a spacer made for the diff end?
[Edited on 27/5/09 by blakep82]
________________________
blakep82
posted on 27/5/09 at 08:43 PM |
http://www.locostbuilders.co.uk/viewthread.php?tid=114280
might be worth asking the length?
robbydee
posted on 27/5/09 at 08:47 PM |
thats for an english diff though... is that different to the sierra one?
posted on 27/5/09 at 09:09 PM |
Worst result would be the large imbalance forces caused by the UJ not being adequately supported causing a fatigue fracture and the prop letting go.
If the gearbox tail housing has already broken then it's time to get it fixed properly IMO.
blakep82
posted on 27/5/09 at 09:10 PM |
i thought they were the same? or is that atlas and sierra that are the same?
owelly
posted on 27/5/09 at 09:14 PM |
Just get a 20-30mm spacer for the prop-diff flange.
http://www.ppcmag.co.uk
dave1888
How about fitting a spacer between the prop and rear diff. 20mm or so.
robbydee
posted on 27/5/09 at 09:16 PM |
anyidea where i can get a spacer?
aerosam
posted on 27/5/09 at 09:22 PM |
Any good local engineering workshop should be able to make one for you. As you have the prop removed, take it down and they will use the end of it as
a template.
Had enough of this dictatorship known as LCB. Gone elsewhere, not coming back. Kiss my ass ChrisW.
robbydee
posted on 28/5/09 at 09:30 AM |
Just ordered a new Bailey Morris Prop....
Should be here Monday, ...
posted on 28/5/09 at 10:04 AM |
That was by far the best solution. A thin spacer on the diff end might be ok, but you are essentially transferring the problem to the other end of
the prop.
MikeR
posted on 28/5/09 at 12:08 PM |
i'm with the rest - should be about an inch further in the gearbox.
