New Topic New Reply
Author: Subject: bleeding willwoods
gjs
posted on 1/6/09 at 06:01 PM Reply With Quote
bleeding willwoods
Has anyone done this before,need some advice.Got 4 pot willwoods on front,and cant get a good pedal after trying to bleed,is it because the MC is lower than the caliper etc.Please help
Flamez
posted on 1/6/09 at 06:07 PM Reply With Quote
Furthest wheel away first, and bleed all 4 nipples on the caliper.
It worked for me.
my build mac1motorsports
mistergrumpy
posted on 1/6/09 at 07:04 PM Reply With Quote
When I helped Gav with his we took the caliper off the mount and tipped it slightly and we did the nipples closest to the inside of the car first. We did it two or three times and the tipping the caliper definitely helped, there must've been an air bubble trapped there.
gjs
posted on 1/6/09 at 07:06 PM Reply With Quote
thanks guys,the wilwood site says something along them lines of keeping the caliper vertical.
nitram38
posted on 1/6/09 at 07:58 PM Reply With Quote
Also make sure that your wheel bearings are tight because any runout of the disc caused by them will push the pads back too far and give you the feel of a soft pedal.
flak monkey
posted on 2/6/09 at 11:48 AM Reply With Quote
It can be a long job.
Only ever use the top nipples on the caliper to bleed it. To start with undo them both and get the majority of the air out. Then do one at a time starting with the outside nipple first.
Sera
http://www.motosera.com
New Topic New Reply
