Author: Subject: Quaife reverse mounting direction
Triggerhappy
posted on 5/6/09 at 07:38 AM Reply With Quote
Is there an designated direction...or can i rotate the box 180degrees, eg is the box directional in what flange is input and out put.
I realize the opening for amusing answers on this stupidly put question, be merciful
Im from Sweden, so im escused...The Muppet drummer for president!!
Mr Whippy
posted on 5/6/09 at 07:56 AM Reply With Quote
I believe diffs are directional and can't be used in the opposite direction (other than reversing the car) without the contact points on the cogs needing realigned through shimming. Basically the back of the cogs teeth will be overlapping the other cogs teeth at the wrong location i.e. the edge rather than the center and so will wear badly.
stuart_g
posted on 5/6/09 at 08:03 AM Reply With Quote
I think that the Quaife has to be mounted a particular way as the bearings are different on each end. I think it is mounted with the reverse lever to the passenger side but i'm not 100% sure on that.
I'm sure someone will be along to confirm.
hoots_min
posted on 5/6/09 at 08:32 AM Reply With Quote
Trying to think from memory, but I believe ^^^ is correct, lever is on the passenger side. I don't think you would want to reverse the direction of the Quaiffe anyway, the unit is horrible going in reverse definitely smoother going forward. Or maybe that is just mine.
Today is a good day: I achieved new heights of ineptitude.
skippad
posted on 5/6/09 at 08:50 AM Reply With Quote
definately reverse lever on passenger side,
filler plug driver side.
Triggerhappy
posted on 5/6/09 at 09:08 AM Reply With Quote
So to clarify as im in Sweden with an LEFT hand side drive car.
Oil filler to the right!
Lever to the left!
Phil.J
posted on 5/6/09 at 09:30 AM Reply With Quote
I don't really know but I love that sponge mallet!
stuart_g
posted on 5/6/09 at 10:07 AM Reply With Quote
Lever to the left!
Correct?
Yes that would be correct, Sorry didn't realise you were in Sweden
fege
posted on 5/6/09 at 10:22 AM Reply With Quote
Lever to the left!
Correct?
Correct! If I remember correctly the unit has two bearing on the shaft pointing backwards (if mounted like in the picture) and one on the shaft pointing forward.
Triggerhappy
posted on 5/6/09 at 11:05 AM Reply With Quote
Many thanks for replys, your the best
Re the mallet, its pretty darn hard plastic if you ask my left thumb, iŽll fully agree on that it looks like sponge thou...
