Author: Subject: Battery light denso alternator
Gary 7
posted on 9/6/09 at 04:25 PM Reply With Quote
Just changed to a small denso alternator 3 wire hook up, battery , ignition lamp and switched live.The battery light is staying on but the battery is charging at 14.4 volt .The warning light is a bright 6 module,if i reconnect my original alternator the light goes out.
Anyone had the same problem with the warning light.
Mr G
posted on 9/6/09 at 04:27 PM Reply With Quote
Due to the way the charge light output is wired up you need to fit a transistor.
It's been covered before, a search should bring it up
LINKY
transistor solution is detailed in macbeasts post second from last.
And whitestu post confirming he got it working ok HERE
[Edited on 9/6/09 by Mr G]
flak monkey
posted on 9/6/09 at 04:31 PM Reply With Quote
Do you need a transistor?
Havent done this myself yet, but will be when I change engines. I know mine has IG, L and S connections, but whats what I dont know!
This webpage has some useful info:
http://westfield-world.com/daihatsu_alternator.html
And here are all the regulator types with the pins labelled:
http://www.fae.co.za/Web%20Catalogue%20Pdf/Regulators/Nippondenso%20Regulators.pdf
[Edited on 9/6/09 by flak monkey]
Sera
http://www.motosera.com
Gary 7
posted on 9/6/09 at 04:49 PM Reply With Quote
Been searching for a solution must have missed that one. many thanks.
whitestu
posted on 9/6/09 at 05:06 PM Reply With Quote
Mine's still working fine with the transistor.
It seems unusual, but the alternator outputs a 12v signal to the charge light when stationary, but it is just a signal - there's no current behind it to light a bulb / high power LED.
The transistor switches the LED on my acewell to earth when it gets the 12v signal so putting on the light.
Stu
[Edited on 9/6/09 by whitestu]
