Author: Subject: Reverse Thread on Hubs
ashg
posted on 12/6/09 at 03:58 PM Reply With Quote
just to make sure im not going mad. the reverse threads on the front and rear sierra hubs go on the (uk)Drivers side of the car.
Am i correct?
[Edited on 12/6/09 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Flamez
posted on 12/6/09 at 03:59 PM Reply With Quote
tighten towards the front of the car on both sides
my build mac1motorsports
P ?
posted on 12/6/09 at 04:00 PM Reply With Quote
ive recently put my rear hubs on and i dont have a clockwise thread on eitherside :S
ashg
jesus that was quick
Flamez
posted on 12/6/09 at 04:01 PM Reply With Quote
The reverse nut also has a notch cut into it for id,
ashg
posted on 12/6/09 at 04:03 PM Reply With Quote
striped my hubs down ages ago and almost forgot which carrier went with which hub lol.
now i just have the joy of doing them up to 280nm. oh what fun that will be
Land Locked
posted on 12/6/09 at 04:07 PM Reply With Quote
With a long enough lever anything is possible.
We had a 1.5 metre long torque wrench at the dealers for type 3 rear hubs, which if i recall was something along the lines of 280Nm.
deezee
posted on 12/6/09 at 04:10 PM Reply With Quote
I'm in the same boat as I'm just popping my hubs and axles on after recon.
The front Drivers side hub is a reversed / left handed thread (marked by notches)
The rear Passenger side axle uses a reversed / left handed thread (marked by notches)
So the left handed-ness is diagonal.
ashg
posted on 12/6/09 at 04:16 PM Reply With Quote
are you sure. i recall the reverse threads both being on the same side when i took the sierra appart.
Macbeast
posted on 12/6/09 at 04:51 PM Reply With Quote
Sierra manual - Fronts
" Note that on all models manufactured before late December 1982 both laft and right (front hub) nuts have a right-hand thread but from this date left hand-thread assemblies were progressively fitted to the right-hand hub carrier. "
Rears
"The left-hand nut has a left-hand thread
"Left and right are in the sense of a person seated in the diriving position facing forwards "
HTH
MautoK
posted on 12/6/09 at 11:03 PM Reply With Quote
Erm...how do you rotate something 'to the front'?
Half of it goes to the front and half of it goes to the back.
