Author: Subject: help me work out my tyre sizes...
aerosam
posted on 21/6/09 at 12:59 PM Reply With Quote
I have fitted 245/45/R17 tyres to the rear, I want to fit 225 wide tyres to the front, so what profile should they be to match the rears?
The wheels are 8.5J x 17inch.
Thanks!
Had enough of this dictatorship known as LCB. Gone elsewhere, not coming back. Kiss my ass ChrisW.
Mark Allanson
posted on 21/6/09 at 01:06 PM Reply With Quote
Why do they have to match?
aerosam
posted on 21/6/09 at 01:15 PM Reply With Quote
because if they are a different diameter they will rotate at a different rate to the rears and confuse the ABS.
Should have mentioned this is for my tintop BMW.
Mark Allanson
posted on 21/6/09 at 01:24 PM Reply With Quote
Ah! I thought it was for your proper car
Mark Allanson
posted on 21/6/09 at 01:29 PM Reply With Quote
Tyre Width Profile Diameter Rolling Dia
225 50 17 25.85826772
245 45 17 25.68110236
Humbug
posted on 21/6/09 at 01:32 PM Reply With Quote
245/45/17 has a theoretical diameter of 65.23cm
225/50/17 has a diameter of 65.68cm, i.e. just under half a cm different depends how sensitive the ABS is
(I calculate a 225/41.3/17 to have a diameter of 61.77cm, quite a lot different...)
[Edited on 21.06.2009 by Humbug]
tul214
posted on 21/6/09 at 01:35 PM Reply With Quote
225/50/17 would give a +5mm difference
225/45/17 would give a -18mm difference
Ha Ha...eta..must type faster!!
[Edited on 21/6/09 by tul214]
1.6 Raw Super6 sold
Macbeast
posted on 21/6/09 at 01:37 PM Reply With Quote
225 x 49
Blxed first answer, sorry
[Edited on 21/6/09 by Macbeast]
aerosam
posted on 21/6/09 at 05:32 PM Reply With Quote
So the 245 wide tyres have a rolling circumference of 102.463cm and the 225 tyres have 103.169cm.
So the front tyres will turn 0.706cm less for every rotation of the rears.
I doubt it's that sensitive - thanks guys!
