Author: Subject: bec indy gsxr
peter bland
posted on 22/6/09 at 10:53 PM Reply With Quote
bec indy gsxr
has anybody had problems with the wiring harness not matching the ecu ie the id codes, and the engine not starting.
twybrow
posted on 22/6/09 at 11:02 PM Reply With Quote
Is that the worlds largest Avatar?
200mph
posted on 22/6/09 at 11:07 PM Reply With Quote
and in the IVA/legal section?
/confused
(unless of course it's irony?)
If it isn't broke, fix it until it is
andyd
posted on 23/6/09 at 08:05 AM Reply With Quote
And you wouldn't make the screen less bright by adjusting the resolution! It's called the erm... hang on, it'll come to me...
[Edited on 23/6/2009 by andyd]
posted on 23/6/09 at 08:10 AM Reply With Quote
He-war.. still room for my sigs?
Richard Quinn
posted on 23/6/09 at 09:05 AM Reply With Quote
A few helpful responses so far!
To answer the question... No. But, has the car run with this ecu / harness? If not, are you sure it is the same model year harness and ECU? It may be that wiring colours/pin outs changed. I know on some bikes where there was a major upgrade the ecu supplier was changed and even the connectors changed.
Triggerhappy
posted on 23/6/09 at 12:32 PM Reply With Quote
On later gsxr´s, depend on model 600, 750, 1000 and the GSXR1300Hayabusa, the factory imobilizer function will kick in...meaning ECU must accept the key´s RFID code...also meaning the suzuki antenna (In the original igitionlock) must be present.
Im from Sweden, so im escused...The Muppet drummer for president!!
