Author: Subject: Why oh why oh why.....
posted on 23/6/09 at 12:28 PM Reply With Quote
Do manafacturers miss out really cheap (but critical) bits.
Just got a 15mm tank connector from screwfix ([homebrew]making a dinky hop strainer for my copper [/homebrew]). But they haven't included a washer. How much does a tiny little rubber / plastic washer cost? 1p? 2p?
Now I've got to go and find a washer to fit a tank connector and will probably end up going to Travis Perkins and getting well and truly shafted.....
Aaaaaaaaaaaaaaaaaaaah.....
On the plus side the 25m coil of 8mm copper pipe I got will make both an immersion cooler for the brew and a EFi return line for my Locost conversion....
minitici
posted on 23/6/09 at 12:29 PM Reply With Quote
Admit it your'e making a still
carpmart
posted on 23/6/09 at 12:33 PM Reply With Quote
I can't see how there is anything to admit as it pretty bloody obvious that's what he is making!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
Mr Whippy
posted on 23/6/09 at 12:36 PM Reply With Quote
you'd think he'd know better than to drink that
posted on 23/6/09 at 12:42 PM Reply With Quote
Well if you're asking I'm making 40 pints of all-grain homebrew. Trouble is my poxy 5 gallon boiler doesn't have a hop strainer so the wort gets stuck (ie clogs up the tap).
For some reason homebrewers use their own language
e.g.
copper = (usually plastic) boiler
liquer= water
alkalinity = buffering ability of carbonates in the water (ie not just opposite of pH)
Can't decide what brew to do though-
Wadworth 6x
Black Sheep Ale
Timothy Taylor Landlord
Adnams Broadside
I would make a still but I think the police might have me under surveillance after my cheeky e-mail re loud exhausts in Devon and Cornwall
rb968
posted on 23/6/09 at 12:57 PM Reply With Quote
Black Sheep mmmmmmm....
cd.thomson
posted on 23/6/09 at 01:07 PM Reply With Quote
can't decide what brew to do though
Is this your first attempt? If so, it doesnt matter what you call it - its still going to be moonshine
Craig
wilkingj
posted on 23/6/09 at 01:35 PM Reply With Quote
Eh Wot??
Black Sheep.... Bah... I'll get me wellies
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 23/6/09 at 02:17 PM Reply With Quote
It's my first all grain, previously been working up to it with partial mashes.... I didn't have enough space to do it until recently so I've read five books on the subject (including a rather hefty tome on brewing chemistry).... We'll see how it turns out!!!
smart51
posted on 23/6/09 at 02:43 PM Reply With Quote
Home brewed beer. A house mate of mine tried this when we were students. The student house was usually freezing cold but varied in temperature a lot. Not ideal conditions for brewing. He said it tasted really good but was best served with a kaolin and morphine chaser, such was its effect on the body's digestive system. He stored the bottled product in the bottom of his wardrobe for some reason. One night he was woken by a huge Whoomph noise as the pressure inside the bottles became too much for the glass to hold in. It put an end to the diarrhea but did mean he had to wash all his clean clothes.
JeffHs
posted on 23/6/09 at 03:05 PM Reply With Quote
Good luck with the brew. let us know how it turns out. I'd be very interested in how much gravity you manage with your mash. I've been doing full grain beers for years but try as I may, I can't get as good a yield as the books say I should, so I end up cutting the volume and then it's too bitter because i added too many hops to the boil.
It usually gets drunk though!
posted on 23/6/09 at 03:19 PM Reply With Quote
We'll see. I'm aiming for 75% efficiency because I'm batch sprarging... If that doesn't work I'll switch to fly-sparging..... We shall see!!!! Just getting all the bits together and then waiting for some cold weather as I haven't got enough space for a seperate fermentation fridge....
posted on 23/6/09 at 03:31 PM Reply With Quote
I would have thought that clothes washing was necessary after the first condition...
aerosam
posted on 23/6/09 at 03:54 PM Reply With Quote
what the heck is sprarging? or sparging? Does that mean you give up and just nick the beer from spar?
posted on 23/6/09 at 04:26 PM Reply With Quote
sparging = after the initial mash (keeping the grain at a constant temperature) you further wash it in a slightly hotter water (now called liquer cos its brewing talk!!) to rinse out the sugars....
Fly spraging = slowly trickling through a little water as you drain the grain, batch sparging = dump in a load of hotter water then drain it.
splitrivet
posted on 23/6/09 at 06:45 PM Reply With Quote
Really fancy having a go at home brew the proper way as your doing, what kit do you need.
Bob
Dangle_kt
its like talking to The Wurzles!
carpmart
posted on 23/6/09 at 07:35 PM Reply With Quote
Bob
well according to the first post, APPARENTLY you need a whole load of copper pipe to brew beer at home
'94 MX5 MK1, 1.8
posted on 24/6/09 at 09:41 PM Reply With Quote
Bob
If you're doing all-grain you need a lauter tun (picnic cooler with some copper pipes in the bottom), a boiler (I used a £60 electrim boiler but you could use a big catering pot or a catering tea urn) and a fermenting vessel. And lots of bottles (or a homebrew barrel). Max cost about £100 but from then on it's 30p a pint The other thing you need is time. A full brew session is 10 hour(ish) which is why often people start brewing large amounts- same amount of time but more beer
