Author: Subject: Iva and the petrol filler cap
big_wasa
posted on 26/6/09 at 08:09 PM Reply With Quote
The iva manual says
"Fuel tank filling points must not be located in the passenger compartment or luggage compartment"
I take this to mean you can no longer mount the filler on the top panel ?
can any one confirm this before I cut a big hole in my rear panel tommorow .
cheers
speedyxjs
posted on 26/6/09 at 08:11 PM Reply With Quote
Thats the way i interpret it. I prefer the look of the cap on the rear or (in my case) on the side
blakep82
posted on 26/6/09 at 08:12 PM Reply With Quote
yeah, you can, as long as there is no floor under the tank.
consider sticking the tank in your boot you tin top. that wouldn't be allowed, but it would if you didn't have a boot floor, if it was just open
you know what i mean?
________________________
locoboy
posted on 26/6/09 at 08:15 PM Reply With Quote
I.e if it has no floor then it can not be a luggage compartment..........
Or alternatively box round the filler pipe, its no different to your tin top then, all that will seperate your weekend suitcase from your fuel filler is a skin of matal called the ibside panel of your boot!
Locoboy
blakep82
posted on 26/6/09 at 08:17 PM Reply With Quote
exactly
big_wasa
posted on 26/6/09 at 08:18 PM Reply With Quote
hmm 50/50
so its not a luggage compartment if there is no floor under the tank.
any more views
I want it on top and already have the fill pipe for that.
Any one passed the iva with this yet ?
[Edited on 26/6/09 by big_wasa]
oldtimer
posted on 26/6/09 at 08:46 PM Reply With Quote
It does say 'in' the luggage compartement, so as long as you don't lift the 'boot' lid to fill up?? - if you have to cut a hole, would that hole be in the rear panel or boot top???
martyn_16v
posted on 27/6/09 at 10:03 AM Reply With Quote
As long as you don't need to open your boot to find the filler cap it should be fine. The way a lot of people have done it before with the filler cap on the top panel next to a boot opening looks ok as far as I can see.
FEZ1025
posted on 27/6/09 at 01:00 PM Reply With Quote
They have just issued a dispensation on this until the 28th April 2010.
Alan...
big_wasa
posted on 27/6/09 at 07:25 PM Reply With Quote
Thanks, on top it goes
