New Topic New Reply
Author: Subject: Exhaust wrap
MautoK
posted on 27/6/09 at 02:37 PM Reply With Quote
Exhaust wrap
Just fitted exhaust wrap to my manifold pipes under the bonnet. As recommended, I wetted the wrap prior to winding it on. Fired the engine up to get a bit of heat into it and evaporate some of the water. All seemed OK...
Today I went just a few miles around town to cook it properly and ended up leaving an acrid smoke trail!
I never realised it would be quite as smoky as that!!
omega0684
posted on 27/6/09 at 02:44 PM Reply With Quote
but do they work now?
what one did you use? how much was it?
anyone used this one
ebay link
[Edited on 27/6/09 by omega0684]
posted on 27/6/09 at 02:46 PM Reply With Quote
Yes - it does smoke - scared the life out of me when it happened, as it was the first time I'd taken it out for a proper drive!
posted on 27/6/09 at 02:58 PM Reply With Quote
Smells as well .
omega0684
posted on 27/6/09 at 03:05 PM Reply With Quote
just found this site that does coloured exhaust wrap, i bet that would look quite funky
Coloured exhaust wrap
MautoK
posted on 27/6/09 at 03:30 PM Reply With Quote
I used the 1" stuff from CBS.
I had thought that 10 minutes tickover would expel the water and that, as they say, would be that.....RONG!
So I was going to go for 10-20 miles, but the smoke (and smell) made me turn for home ASAP.
It's a bit strange trailing smoke, people obviously thinking you're about to burst into flames!
John.
MautoK
posted on 27/6/09 at 04:19 PM Reply With Quote
Better now - just did about 6 miles and smoke and smell are much reduced.
It's great to be able to do more than 3 miles and see the temp gauge steady and just UNDER half-scale.
The bonnet vents are certainly working - you can feel the hot air pouring out.
To sum up, the changes so far to mitigate cooling issues are:
New-to-me engine;
Polo rad;
Both bleeds (rad & 'stat) connected to header tank;
Baffles between radiator and nosecone (top & sides only);
Side vents in bonnet;
Top/rear vents in bonnet;
Headers wrapped under bonnet.
Still to do:
Oil cooler for autobox;
Possibly cut another vent at the back of the nosecone for radiator hot-side air flow;
Possibly duct fresh air to gearbox via NS side panel.
G/box does get a bit hot; it's much tighter in the tunnel than in the donor and I've fitted a sumpS guard which precludes cooling of the auto sump pan.
John.
omega0684
posted on 27/6/09 at 04:22 PM Reply With Quote
have you got an oil cooler for the engine? if not, i would recommend getting one.
did you double layer the exhaust wrap or keep with single?
RichardK
posted on 27/6/09 at 04:35 PM Reply With Quote
I used that coloured stuff and the first header I used it wet and alot of the colour ran out of it so I did the one dry and it turned out alot better, just got to get it tight.
Rich
Gallery updated 11/01/2011
muzchap
posted on 27/6/09 at 05:01 PM Reply With Quote
FWIW : Thermotec is rated as the best stuff to get.
I found a guy in the states who charged peanuts shipping via Ebay and paid £50 for 2" 50ft wrap x 2!
They wanted £65 in England/Europe for just 1 of them...
Plenty of stainless tie grips (with the ball bearing are needed) as well - to help keep everything in place.
Makes you itch like a b'stard - so definitely wet, wear a breathing mask and hate to say it - but Marigolds are essential
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
posted on 27/6/09 at 05:46 PM Reply With Quote
Different ones smell differently. The wrap I got from Merlin motorsport had a nice biscuity smell to it. Made me hungry driving but otherwise no problems!!
stevegough
posted on 27/6/09 at 07:13 PM Reply With Quote
What a brilliant Idea - imagine - differing coloured smoke trails from 5 different cars - find a big empty carpark - eg M25 - sorry, I did say an EMPTY carpark ! and we could do some formations - crossovers, the lot!
Red Arrows, eat your heart out
[Edited on 27/6/09 by stevegough]
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
oadamo
posted on 27/6/09 at 08:49 PM Reply With Quote
http://www.mrsite.co.uk/usersitesv21/aeautomotive.co.uk/wwwroot/page2.htm
40 quid all in for 30m/100ft
adam
New Topic New Reply
