Author: Subject: Fixing wiring to GRP
chrisg
posted on 29/6/09 at 02:24 PM Reply With Quote
I have a need to secure some wiring to the inside of some GRP parts, but how to do it?
I don't want to drill holes in it, will those self adhesive cable tie bases stick to GRP?
Any other ideas?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
richardh
posted on 29/6/09 at 02:25 PM Reply With Quote
little dobs of silkaflex
its messy but strong
Time for a change!
eznfrank
posted on 29/6/09 at 02:26 PM Reply With Quote
If not get a stanley blade and cut the adhesive bit off and use a bit of Sikaflex instead.
Edit - beaten to it ^^^
[Edited on 29/6/09 by eznfrank]
chrisg
posted on 29/6/09 at 02:28 PM Reply With Quote
Yeah, I thought about that but I'm not sure how that would go down with the IVA man.
blakep82
posted on 29/6/09 at 02:33 PM Reply With Quote
i don't think IVA man is generally too keen on sticky bases
________________________
richardh
posted on 29/6/09 at 02:38 PM Reply With Quote
that could be true come to think of it but let him try and pull it off.................
Time for a change!
tomgregory2000
posted on 29/6/09 at 02:39 PM Reply With Quote
i sika flex some 'big head' fastners on the inside of my scuttle so i had studs sticking out that i could fix things to, no problem with sva
blakep82
posted on 29/6/09 at 02:51 PM Reply With Quote
i mean the ones with just the sticky pads. sikaflex will be fine, but not the normal stick pads they have
jabbahutt
posted on 29/6/09 at 03:13 PM Reply With Quote
I used sticky base pads and failed. The examiner suggested removing the sticky foam pad and using sika flex to restick the base to the grp.
No problems with the pass, though this was SVA not IVA. May be worth a phone call to a test station maybe.
blakep82
posted on 29/6/09 at 03:21 PM Reply With Quote
^ you can't phone the test staion anymore, you get a general number in wales i think, speak to someone who's never done an IVA before...
posted on 29/6/09 at 03:25 PM Reply With Quote
If all else fails you could get a little ali bracket, glue it to the inside of the GRP then laminate some glass matt over the top to hold it all in place....
chrisg
posted on 29/6/09 at 04:20 PM Reply With Quote
Thanks for the replies chaps, I've rung my tame IVA man and he's suggested fixing some plastic sheathing with GRP, I'll let you know how it goes.
Chris
MakeEverything
posted on 29/6/09 at 04:37 PM Reply With Quote
I was going to suggest some 20mm PVC Conduit bonded to the rails or inside of the panel. This way, they are mechanically protected to a degree as well.
Kindest Regards,
Richard.
blakep82
posted on 29/6/09 at 04:51 PM Reply With Quote
Chris
was that the centre you phoned, or do you know someone?
mad-butcher
posted on 29/6/09 at 05:00 PM Reply With Quote
now f/glassing over plastic sheathing brings back happy memories of that idiot on kitcar crisis,
tony
chrisg
posted on 29/6/09 at 05:38 PM Reply With Quote
Chris
Someone I know, they've decided that testers "don't have time" to answer queries these days, they just put you through to some pen pusher at VOSA who gives you a stock answer from his card. "I don't have that answer to hand, I'll have to get back to you. Sometimes they do, sometimes they don't - it's a definate step in the wrong direction if you ask me.
Chris
