PAULD
posted on 1/7/09 at 08:09 AM |
Fiesta CV joint
Anyone changed a n.s. outer 98 Fiesta c.v. joint? I need to and havn't. Any advice gratefully received.
Mr Whippy
posted on 1/7/09 at 08:26 AM |
if your keeping the car for a while, I'd recommend you buy a manual for it. Remember to slacken both the wheel nuts and the hub nut before
jacking the car up.
[Edited on 1/7/09 by Mr Whippy]
PAULD
posted on 1/7/09 at 08:58 AM |
It's really the "tricks of the trade" that are often missed by Haynes manuals that I'm fishing for.
need4speed
posted on 1/7/09 at 09:00 AM |
Not a bad job, once you undone the pinch bolt, put a wedge in the gap makes removing the bottom arm much easier. Also have a manual on CD.
Lads got a complete Fiesta on the drive waiting for a trip to the scrap yard, engine is knackered.
Dave.
posted on 1/7/09 at 09:09 AM |
I would suggest getting an exchange recon driveshaft and replacing the whole lot rather then fiddling about replacing just the outer CV joint - unless
it's just the rubber boot you need to replace.
