Author: Subject: Where to get ZX12R Sump baffle plate
maximill666
posted on 1/7/09 at 03:16 PM Reply With Quote
Does anyone know if there is someone that does pre made Sump baffle plates for a ZX12R motor?
Or does anyone have a template?
Thanks.
daniel mason
posted on 1/7/09 at 03:41 PM Reply With Quote
do AB peformance not do all sorts of bits for kawasaki sumps. give him a call.
maximill666
posted on 1/7/09 at 04:07 PM Reply With Quote
I have dropped Andy a u2u to enquire
Smartripper
posted on 1/7/09 at 04:12 PM Reply With Quote
I got one from z-cars,
Daniel
eddbaz
posted on 1/7/09 at 04:34 PM Reply With Quote
AB deffinately do one.
eznfrank
posted on 1/7/09 at 05:43 PM Reply With Quote
Martin Keenan shortened and baffled my standard sump and moved the plug to the side for £40. I had to shorten the pick up myself but that was easy.
maximill666
posted on 1/7/09 at 06:15 PM Reply With Quote
I have a sump that was shortened by martin which also has a small baffle in, but I wasnt sure if the small plate would be enough & may need an additional one.
I also have an accusump system, do you think that the sump as it is plus the accusump system will be enough?
eznfrank
posted on 1/7/09 at 06:39 PM Reply With Quote
Quite a few people run the modded sump on it's own without issues.
eccsmk
posted on 1/7/09 at 07:17 PM Reply With Quote
i only have a shortened sump no baffle fitted and ive driven fairly hard (on a private road) and never had any bother
i am planning on fitting a baffle plate now tho as you've got me worried
imp paul
posted on 1/7/09 at 07:30 PM Reply With Quote
lee spire sports don't run 1 its your call mate
