supercat
posted on 2/7/09 at 09:11 AM |
Rose Joint adapters for Cortina uprights
Does anyone know of a company that would sell adapters to allow me to use rose jointed top wishbones with standard cortina uprights (instead of the
transit ball joint).
James
Mr Whippy
posted on 2/7/09 at 10:07 AM |
Could you not simply ream the hole out to a standard metric bolt size that suites a rose joint? You’ll need to do it very accurately so as not to end
up with play in the bolt.
Not sure why you'd want to do that as the trackrod end will last a lot longer
minitici
posted on 2/7/09 at 10:21 AM |
Like these pins from MNR?
Linky
Or something like the ones I made for Westfield front uprights using a taper adapter with a high-tensile bolt through the middle?
  taper adapter for Westfield
[Edited on 2/7/09 by minitici]
supercat
posted on 2/7/09 at 11:00 AM |
Its for my race car to allow in-situ adjustment...
supercat
posted on 2/7/09 at 11:03 AM |
Linky
I'll give MNR a ring, not sure if those are suitable for standard uprights. The westfield ones look a treat!
Mr Whippy
posted on 2/7/09 at 11:35 AM |
fare enough, those adaptors look smart
procomp
posted on 3/7/09 at 07:09 AM |
Hi
Just remeber to use high angle rosejoints. Std versions do not have the articulation needed. And also use decent quality joints. There's a lot
of rubbish on the market these days. For a decent quality high angle joint expect to pay a Min of £50 if brought as singular items IE not in baulk.
Cheers Matt
