Author: Subject: steering column
Soundwave_666
posted on 12/7/09 at 07:24 PM Reply With Quote
steering column
The first steerign wheel I'm putting in my car will be the ford sierra donor column I got as part fo the kit (money is a bit tight). It has had most stuff stripped off it except for the horn wires and ignition switch. So looks very bare and a bit crap to be honest.
Does anyone have any ideas on makign this look tidy for while it is in? small column of black Vinyl covered foam??? bespoke fibreglass shell?
Steve Hignett
posted on 12/7/09 at 08:23 PM Reply With Quote
Are you on about the Steering wheel or the Column?
eccsmk
posted on 12/7/09 at 08:42 PM Reply With Quote
stolen from iiyama's archive
is this what your after ??
cowl
cowl
Soundwave_666
posted on 14/7/09 at 03:09 PM Reply With Quote
it certainly is. Looks a bit adventurous for my abilities.
DarrenW
posted on 15/7/09 at 10:37 AM Reply With Quote
Upper column mount is an ally cast block with bearing inside. I moved switch to dash and had the ali bit turned and polished (Mac#1 did it for me). All switch gear is on dash. Not as convenient to operate but looks a whole load better.
