New Topic New Reply
Author: Subject: Gear linkage
J16
posted on 14/7/09 at 06:49 PM Reply With Quote
Gear linkage
Does anyone know what the length is of the tube (rose joint at either end) which runs down the tunnel from the gear shift to the mechanism supplied by MK near the engine?
Any help would be most appreciated. Reason is that I didn't get one when I last went to MK as they didn't have any tube left and I'm now trying to manufacture my own!
paulmw
posted on 15/7/09 at 11:42 AM Reply With Quote
Depends on where your gear lever and gear sproket are located
I just bought 1m of alu hollow tube, fitted the gear lever/engine/rocker and cut to fit
It probably ended up at around 600mm but like I say make sure you measure
New Topic New Reply
