Author: Subject: Bellhousing leaking water
hemibum
posted on 14/7/09 at 07:50 PM Reply With Quote
Ford crossflow and after a previous overheating problem is chucking coolant out of the drain hole in the bottom of the gearbox housing. Now, whilst appreciatting that this is likely indicitive of a totally f....d block, can anyone shed any light of cause?
nitram38
posted on 14/7/09 at 07:53 PM Reply With Quote
Core Plug........Corroded.
Gearbox off and it is at the back of the block.
About 50p.
I'm amazed that builders don't change them......................
[Edited on 14/7/2009 by nitram38]
minordelay
posted on 14/7/09 at 07:54 PM Reply With Quote
If I remember right there's a core plug behind the flywheel, it might just be that.
omega 24 v6
posted on 14/7/09 at 07:55 PM Reply With Quote
From a distant memory is there not a core plug behind the flywheel???
Miks15
Gte the gearbox off if you can and keepo the engine in the chassis if possible and turn it on and see where the waters coming from, should be fairly obvious.
If its "chucking" it out it should be easily spotted
omega 24 v6
posted on 14/7/09 at 07:56 PM Reply With Quote
Wow 3 answers the same in 3mins
gazza285
posted on 14/7/09 at 08:36 PM Reply With Quote
Happened to me, took the 1100 out and put a 1600CVH in instead. Was in a Mk4 Escort though.
posted on 14/7/09 at 08:41 PM Reply With Quote
If it's in a locost it will be easier to remove the engine to replace the core plug. Would be a good idea to fit a set while your at it!
hemibum
posted on 14/7/09 at 09:20 PM Reply With Quote
Jeez Guys !! You've just made my day.
Was thinking cracked block at the least.
Core plug? Not a problem!!
Thanks.
austin man
posted on 14/7/09 at 09:26 PM Reply With Quote
happened to me with a 1300 kent engine just chucked an egg in to the cooling system sorted it no problem. deffo the core pug just seperate the engine and fit a new one.
hemibum
posted on 14/7/09 at 10:21 PM Reply With Quote
Ahem, After dancing a wee jig realising that it's only a bloody core plug, can anyone tell me if I can still get one from my local friendly Ford dealer?
MikeR
posted on 15/7/09 at 06:47 AM Reply With Quote
burtons, local ford and decent motor factor should all do them
posted on 15/7/09 at 07:54 AM Reply With Quote
As rusty said - if one's gone, it's a fair bet that all will need replacing.
You'll have to get the engine out to get at the one behind the flywheel, so it's a perfect time to change them all. You'll probably find that they'll look perfect on the outside, but severely corroded behind.
