Author: Subject: bike engine help
Stuart_B
posted on 15/7/09 at 07:52 PM Reply With Quote
bike engine help
hi all, at the moment, i am just looking at options for an engine conversion, so i throught about bike engine, is there a bike engine which the exhaust comes out teh same side as a pinto, and go over the top chassis rail or does it have to come out the side?
as well about paddle shift is this a hard thing to do?
thanks
stuart
200mph
posted on 15/7/09 at 07:59 PM Reply With Quote
every time I think about a paddle shift I get excited - and it's making me want a bike engine.
I could sell you my brand new zetec and I could get a bike engine
If it isn't broke, fix it until it is
Stuart_B
posted on 15/7/09 at 08:02 PM Reply With Quote
i do not want a zetec, it is either duratec or possible bike.
i all way wanted a squential gearbox
Gav
posted on 15/7/09 at 08:10 PM Reply With Quote
Due to the angle of the dangle the exhaust ports will be pointing down, hence going under the rails, unless you can get you engine high, VERY high
Also with the sprocket output being on the left hand side (i carnt think of anything that would be suitable and on the right) the engine will be lent over to the left side of the car to get the output facing backwards.
And yes paddle shift is shiny
The linkage isnt hard to do but find something to use as the paddle might be harder, have a look at the gallery on my website, www link below
[Edited on 15/7/09 by Gav]
Stuart_B
posted on 15/7/09 at 08:13 PM Reply With Quote
hmm, that means i need a new bonnet as well.
i think i will have to see how much money i can save before the winter comes here.
stuart
DRC INDY 7
posted on 15/7/09 at 10:10 PM Reply With Quote
put a 2.0 pinto in on bike carbs dont go bike engine
or cosworth with or without turbo
bike engines are for bright day peeps :
Puddle Dodgers Club
mark chandler
posted on 15/7/09 at 10:11 PM Reply With Quote
Pan european V4 maybe? just drap a pair of pipes around
matt.c
posted on 16/7/09 at 05:04 AM Reply With Quote
Are you sure you want to go bike engine? CEC's are alot more pratical.
I cant believe i said that!
YQUSTA
posted on 16/7/09 at 07:03 AM Reply With Quote
Paddle shift is easy.
I made my own from scratch using a cable for shifting and it works with the stick shift too. Which was a surprise to me
YQ
Farway
posted on 16/7/09 at 09:31 AM Reply With Quote
Pan engine would be way under powered and the transmission drive will give you endless bother to convert..
roadrunner
posted on 16/7/09 at 12:29 PM Reply With Quote
i went pinto to zx9r, had to buy a new bonnet because of the exhaust and the bulge gives you more room for the filter.
if you are going to do it, do it right get a new bonnet.
Oh also if you go bec you wont regret it.
Stuart_B
posted on 16/7/09 at 07:33 PM Reply With Quote
hmm, now i am so confused on what engien to chose, well i have till winter to decide.
thanks
stuart
