<<  1    2  >>
Author: Subject: SVA pass-woo hoo. Engine woes-boo hoo
Neil P
posted on 16/7/09 at 08:43 PM Reply With Quote
Took my car in to Beverley yesterday for SVA re-test. Went through no problem and I drove it home clutching my newly acquired MAC.
On the way back it started misfiring and cutting out and then started making a God awful clattering noise. It seemed to be running very hot when I took the bonnet off.
Have a look at the video, anyone like to take a punt on what is happening?
Neil
Engine noise
Jasongray5
posted on 16/7/09 at 08:47 PM Reply With Quote
Well done on your pass mate!
Not a clue about the engine, but it sounds like a derv now???
Dropped a valve maybe?
[Edited on 16/7/09 by Jasongray5]
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
LBMEFM
posted on 16/7/09 at 08:48 PM Reply With Quote
Have you an oil pressure gauge or checked the oil level, sounds like big ends to me.
mookaloid
posted on 16/7/09 at 08:50 PM Reply With Quote
certainly doesn't sound good - hard to tell exactly where it's coming from but it could be a knackered cam or big ends or valves hitting a piston.
You need to have a look inside, but most likely you need a new engine
Congrats on the pass by the way
nitram38
Dropped a valve or broken a camshaft?
Neil P
posted on 16/7/09 at 08:51 PM Reply With Quote
I'm wondering if this is a good excuse to find a 20v instead.
Bloody annoying though, at the point I get it through test it breaks.
Neil
richard
posted on 16/7/09 at 08:52 PM Reply With Quote
does not sound good, do not know a lot about these engines,( pinto for me ) but sounds endy.
clairetoo
Maybe cam timing - slipped / stripped / jumped cam belt ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
Neil P
posted on 16/7/09 at 08:53 PM Reply With Quote
Pretty sure the noise is coming from within the block rather than the head.
Makes you cringe when you stand next to it.
Neil
rost
posted on 16/7/09 at 08:54 PM Reply With Quote
Same thing happened here on a 20V 4AGE, turned out two big-end bearings failed! They tend to get stuck to the crankshaft after sitting still for a while, they'll fall out eventually. I've head of ofther occasions of this happenign. Don't run the engine, cause it will make things worse!
The bearings were a pretty easy fix, just remove the oil pan and you're able to un-tighten the rods, check if the bearings are still attached firmly and if they're in good shape! If it damaged your crank you'll problably be off cheaper by buying a 20V indeed!
[Edited on 16/7/09 by rost]
Charlie don't surf!
miikae
posted on 16/7/09 at 09:06 PM Reply With Quote
After listerning to it a few times my money is on the big ends kaput , drop the sump and check big end caps are all ok , no broken bolts etc.
Mike
If it can be done it i will be done .
posted on 16/7/09 at 09:09 PM Reply With Quote
Check the cam and crank pulleys are tight.
Neil P
posted on 16/7/09 at 09:11 PM Reply With Quote
I'll have a look at the big ends. Not sure why they would give up quite so quickly, though. (about 40 miles)
Neil
MautoK
posted on 16/7/09 at 09:33 PM Reply With Quote
Sounds 'endy' on the face of it, but it seems a little too high pitched - not a heavy enough sound from my experience.
However, dropping the pan will give you a simple yes/no.
I had an MG Midget (A Series) some while back and fitted an aftermarket belt drive for the cam. The cam wheel was very slightly thinner than the original sprocket; the bolt didn't pull down tight onto the wheel, so it had a few degrees of slack onto the Woodruff key. That gave a similar noise to yours, Neil. It was rpm-dependent and a pig to diagnose (engine out twice!).
There again, if the engine has been standing a long time, and if the oil system didn't prime on first restart it could easily melt a shell or many.
John.
PS I once bought an Imp knowing that the big ends were shaky - 'bit of a tap after 10 miles', so I was told. Got home, dropped the sump, put #3 big end cap on the right way round and subsequently did lots of miles, trials, autotest with no problems!
splitrivet
posted on 16/7/09 at 10:18 PM Reply With Quote
Sounds like big ends for sure.
Bob
Nash
posted on 16/7/09 at 10:40 PM Reply With Quote
Big end knock. Is there metel in the oil?
Re: it happening so quickly, do you have oil circulation. Are your oilways free flowing? Are the bearings rollers or shells? If they're shells and they aren't getting lubricated they will drop out very quickly!
work out how many revolutions the shells have done
40 miles at average of 20mph = 120 minutes of work on average. Assume an average RPM of 3000 x 120 minutes = 360000 revolutions. That would be more then enough time to wipe a white metal bearing if not lubed. Check the oil for "bits" and drop the sump
Good luck
.........Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
Land Locked
posted on 17/7/09 at 07:11 AM Reply With Quote
Sounds like big ends to me.
gaz_gaz
posted on 17/7/09 at 07:40 AM Reply With Quote
big ends almost certainly,
i had the exact same noise last week while driving my other halfs car,
oh she was pleased
Andy D
posted on 17/7/09 at 07:54 AM Reply With Quote
Does it have a shortened sump? perhaps the crank is catching it? If not, it sounds pretty major...
jpindy3
posted on 17/7/09 at 07:59 AM Reply With Quote
well done,'how come you did a sva??
im sorry to hear that nosie but i think you will find that engines buggerd
posted on 17/7/09 at 09:07 AM Reply With Quote
Sounds like
Big end knock. My friend's daughter has blown two of these in her MR2 and they sounded just like that
speedyxjs
posted on 17/7/09 at 11:49 AM Reply With Quote
Anyone who failed SVA before the IVA came is has up to 6 months to retest under SVA rules.
Well done on the pass, sorry to hear about the engine
mad-butcher
posted on 17/7/09 at 04:27 PM Reply With Quote
put it in in for dvla inspection as it is, they don't need to hear it running, otherwise I can forsee an engine number not matching the one on the documentation problem
tony
Ninehigh
posted on 17/7/09 at 07:29 PM Reply With Quote
I had an escort that sounded like that until the exhaust broke off at the manifold... Other than that I can tell you it's not the tappets!
Ford told me the rattling was the alternator so might be as well checking that too...
Neil P
posted on 17/7/09 at 09:55 PM Reply With Quote
That was my diagnosis
Thanks for the suggestions. I don't know what sort of oil pressure was building up but I could see it delivering oil over the cams.
I'll have a look up her bottom and see what's going on.
Neil
<<  1    2  >>
