Author: Subject: Sorry another Sierra steering rack question - should be a quick answer!
Chaz
posted on 17/7/09 at 06:29 PM Reply With Quote
I need to disassemble the steering rack to put in my new quick rack.
How do i get the old steering gear rod out? Do i need to take out the steering column pinion first?
If thats correct, then how do i get that metal shroud off which holds the pinion in?
posted on 17/7/09 at 06:42 PM Reply With Quote
The quickrack is easy to fit in the shortened casing. Simply remove the slipper plug, then loosen and remove the pinion nut, together with the pinion. Slide the old rack out and the new quickrack in. Replace the pinion, tighten the pinion nut and then screw in the slipper plug. Don't screw the slipper up too tight though.
Phil
[img][/img]
mookaloid
posted on 17/7/09 at 06:44 PM Reply With Quote
I made myself a tool which slots into the surround which holds the pinion down in its housing. It's a bit stiff at first as they are centre punched into place but once it's unscrewed the pinion just pulls out.
You can then pull the rack out and replace.
You might need to back off the adjuster to get the new one in but you should be able to see how it works by this point.
Mark
Edit: or just look at the above
[Edited on 17/7/09 by mookaloid]
Mark G
posted on 17/7/09 at 06:50 PM Reply With Quote
do you not have to cut the new rack inner down and tap the end before you fit it?
Chaz
posted on 17/7/09 at 08:20 PM Reply With Quote
Ahh i see. Its the slipper plug which sounds like it would slip right out!
This has not been the case. So youre saying i need to manufacture a tool to unscrew the pinion nut, ok.
Thanks.
[Edited on 17-7-09 by Chaz]
