Author: Subject: ZETEC Crank Sensor + megajolt
RMarine
posted on 17/7/09 at 08:31 PM Reply With Quote
i have just got my megajolt "complete zetec fitting kit "in the post today. i have had a quick look at the instuctions to find loads of referance to a trigger wheel needing fitting to the engine (are they talking about a zetec engine or talking about engines in general?) . i have a 1993 1.8 zetec. Do i need to fit a new trigger wheel or do i just use to zetec crank senor?
UncleFista
posted on 17/7/09 at 08:32 PM Reply With Quote
Just use the Zetec crank sensor and flywheel
Tony Bond / UncleFista
big_wasa
posted on 17/7/09 at 08:34 PM Reply With Quote
No you all ready have one or should have on the zetec.
It sticks through the block and points at the back of the flywheel and sits under the exhaust side.
Steve G
posted on 17/7/09 at 08:35 PM Reply With Quote
As above - the holes in the back of the Zetec flywheel are used so dont need a trigger wheel and seperate sensor like the Pinto etc. You will find the VR sensor just above the starter motor on a Zetec
posted on 17/7/09 at 08:37 PM Reply With Quote
Just use the VR already in the block looking at the flywheel, just make sure you use the standard shielded loom to as close as possible to the ECU (or EDIS).
Reference to trigger wheel will just be fro engines not equipped with a crank sensor, ie: pinto, crossflow etc.
RMarine
posted on 17/7/09 at 08:46 PM Reply With Quote
Whats a "standard shielded loom" ?
snapper
posted on 17/7/09 at 09:45 PM Reply With Quote
The Megajolt instalation likes a twin core cable from the sensor to the Megajolt ECU that has an earth shield around it, pretty standard sheilded cable which you can buy from Trigger wheels .com
You Megajolt loom should be well built and sheilded and earthed as per the instructions.
Do it right, do it once...... or you will chase problems (as i have done) for a long time.
I eat to survive
I drink to forget
Steve G
posted on 17/7/09 at 09:52 PM Reply With Quote
Shielded cable - you can get some from Maplins etc. Basically a metal braid surrounding the signal wires stops electrical interference from affecting the signal from the VR sensor to the ECU.
RMarine
posted on 17/7/09 at 11:59 PM Reply With Quote
thanks guy's
RichardK
posted on 18/7/09 at 09:12 AM Reply With Quote
Think I remember too that you only ground one end of the shielded wire on the shielded cable too. Maybe worth looking into that just in case I dreamt it
Rich
Gallery updated 11/01/2011
