Author: Subject: Picasso prob....any idea's
AndyW
posted on 18/7/09 at 09:44 AM Reply With Quote
Have not had time to look at it yet but the wife car has a little prob which I need to sort soon. Its 2001 Picasso. Problem is that when you go to wash the windscreen the wipers sweep as normal but the water comes out the rear screen jet and not the front!! When you wash the rear screen that works as normal. Any Idea's before I start?
Cheers in advance
Andy W
Howlor
posted on 18/7/09 at 09:48 AM Reply With Quote
Just get her to reverse everywhere?!
huskychaser
Re- washers
Hi, sounds like a faulty wash / wipe switch.
iceman26
posted on 18/7/09 at 10:05 AM Reply With Quote
some french cars use 1 pump for both with a switch over valve in the pump
if it only has one
pump then it will prob need pump
AndyW
posted on 18/7/09 at 10:09 AM Reply With Quote
its bad enough watching her go forward.....
posted on 18/7/09 at 10:14 AM Reply With Quote
French car electrics are ****
Could be a bad earh connection at the pump/valve.
AndyW
posted on 18/7/09 at 10:43 AM Reply With Quote
thanks guys, will have a check later....
posted on 18/7/09 at 02:07 PM Reply With Quote
Likely to be a faulty valve in the pump
Gazeddy
Most likely want a new washer pump mate.most cars now only use one a have a valve which controls flow dependant on which way the
pump is goin
eccsmk
posted on 18/7/09 at 06:02 PM Reply With Quote
as others have said it will be a faulty pump
they arent that expensive to replace
linky
