New Topic New Reply
Author: Subject: MK Exhaust / Silencer Problem
alister667
posted on 16/3/04 at 06:50 PM Reply With Quote
I finally recieved my MK exhaust, but it doesn't appear to be a good fit at all. I'm hoping for advice.
I had the manifold piece before Christmas, but due to one thing and another I didn't get the silencer end until yesterday. Only problem it doesn't seem to fit. There's an adapter section with the silencer, but it doesn't fit over the manifold end as you'd expect, and it seems to be too short - leaving the silencer too far away from the rear wheels. The angles seem all wrong too. Everything is MK - so I'm wondering is the adaptor pipe for a Pinto engined car and not a Blade?
Any ideas? Have a look at these pics, maybe they'll explain better!
and
http://members.lycos.co.uk/alister667/
Lightning
posted on 16/3/04 at 07:51 PM Reply With Quote
I have an MK blade exhaust . The collector on the manifold pipie does not look like mine. My angles were fine except 25mm too close to the car. I have put that down to the fact that the car is a Tiger not MK and had to cut and shut and weld sections Still cheaper than getting one made .
Check with Martin, he is bound to sort it out , measure the diameters first, my manifold pipe is 50mm OD
alister667
posted on 16/3/04 at 07:59 PM Reply With Quote
The outside diameter of my manifold pipe is 2 and 1/4 inches - about 56mm. It definitley is a Blade manifold, it fits like a glove!
The other point I forgot to mention is my MOT is on Monday. AAARRRGGGHHHH!!!!!!!
I have some piping that I can rig something up with if I don't get it sorted out by then. Should be OK.
Mk-Ninja
posted on 16/3/04 at 10:03 PM Reply With Quote
As lightning says give Martin a ring, I am sure he will sort you out /advise you what to do.
I'm sure I've got one, just don't know where I've put it
loafersmate
posted on 16/3/04 at 11:25 PM Reply With Quote
It's a bit difficult to see from your photo's but the joining piece should be bent at roughly the same angle as the bend in the side panel. The manifold is roughly parallel to the front part of the sidepanel, then you have the bent adaptor and then the silencer sits roughly parallel with the rear part of the sidepanel (mine is pushed in slightly to get the silencer on the mount), see fr_susp in my photo's.
Ben
david cromie
posted on 17/3/04 at 12:21 AM Reply With Quote
mk exhaust.
you7 do not have the right adaptor from the dowm pipes unto the silencer. Mine goes over the downpipes and you should have stainless steel clips to hold it on. Mine did not fit right even with the right pieced and i ended up cutting the adaptor and re welding it up again. Mine is in my opinion still to near the bodywork, silencer that is. Hope this of some help David
posted on 17/3/04 at 12:22 AM Reply With Quote
Adapter
Our's came with a bent adapter as Ben says...
You need one quick!
alister667
posted on 17/3/04 at 01:15 PM Reply With Quote
The Answer
I was on the phone to MK this morning and I have the answer if not (yet) the solution. It seems since I had my manifold delivered (October 2003) there has been a change in this part. The silencer and the adaptor pipe are made for the newer manifold. The newer part has a smaller diameter collector, and is further back on the car, so my pipe doesn't fit it and even if it did the silencer would be in the wrong position. The delay in getting my silencer was basically due to Bill Adair (Ireland MK agent) being extremely busy, and Bill and MK are doing their best to sort it out. I suspect they'll have a new adaptor pipe made that will taper down to the right size, and also provide the right length. The only other alternative is a new manifold, but at £200 quid a pop I don't think that'll happen.
Thanks for the help folks. I'll let you know what happens.
Alister
alister667
posted on 17/3/04 at 01:17 PM Reply With Quote
Oh yes, and a happy St. Patrick's Day y'all!
alister667
posted on 17/3/04 at 07:28 PM Reply With Quote
With a lot of help from my Dad we knocked up an adaptor that works well.
I expect I'll get a nice shiny stainless steel adaptor from Bill at some point, but I should have enough to get me through the MOT.
Thanks again for the help.
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 17/3/04 at 07:31 PM Reply With Quote
well done Al! good luck with your mot- mine is on friday!
[Edited on 17/3/04 by scotlad]
alister667
posted on 17/3/04 at 08:54 PM Reply With Quote
Scotlad,
Thanks very much, and good luck yourself.
macspeedy
posted on 17/3/04 at 09:08 PM Reply With Quote
good luck with the test, we should get together soon as i am also in edinburgh
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
posted on 17/3/04 at 09:45 PM Reply With Quote
yup no worries- be out and about soon i hope- mango has you listed in the 'want a shot in' queue already
macspeedy
posted on 18/3/04 at 07:26 PM Reply With Quote
where's this queue?
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
posted on 18/3/04 at 11:16 PM Reply With Quote
mangogrove has already said you would like a shot so i'll give you a shout when its on the road. driving it to the mot- should be a laugh- hope nothing falls off!
posted on 19/3/04 at 12:54 AM Reply With Quote
Sure it won't...
... not with you building it...
Good luck that man!
PS Do you still need that aluminium for the prop
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
posted on 19/3/04 at 10:33 AM Reply With Quote
yes yes yes please-using crappy steel box section- not good but do for mot!
New Topic New Reply
