<<  1    2  >>
Author: Subject: Weasel power
Ninehigh
posted on 22/7/09 at 10:52 PM Reply With Quote
Weasel power
Any thoughts of using a diesel engine in a 7? If you were forced to use one what would you have?
graememk
posted on 22/7/09 at 11:05 PM Reply With Quote
no dont do it
but vauxall make a very nice 90bhp 1.3cc
and a 1.9 150 bhp both respond very well to re-mapping
gear box ? 1.9 sould fit something alfa / fiat
blakep82
posted on 22/7/09 at 11:24 PM Reply With Quote
always wondered if the vauxall diesels from 1998 for example would have the same block as the xe or xev? although i guess the gearing in a type 9 box wouldn't be perfect
________________________
Ninehigh
posted on 22/7/09 at 11:32 PM Reply With Quote
Ah here's the thing, why not?
Bags of torque, hardy engine and like you say modern ones of the size most people are talking about give 150bhp stock. Imagine what you could get with a remap, a few tweaks and a big-arse turbo (maybe a twin one too )
All with the advantage of 50+mpg when you take it easy and still over 20 at full power
I got the 2l tdci in my mondeo and it's good for nearly 130mph, how would that feel in a seven?
PAUL FISHER
posted on 22/7/09 at 11:49 PM Reply With Quote
Westfield made a factory supplied 90 bhp1.6 ford turbo diesel back in mid 80's,it did 0 to 60 in 6.5 seconds,I remember it because I had just bought a new XR2 at the time,and that could only manage 60 mph in 8.5 seconds.
Ive been thinking about it for my next build,along with just about every other engine out there,but have come to the conclusion that the best diesel engine would be the bmw 320d 2006/2007 onwards,coupled to its 6 speed box,and its own 2.56 ratio diff,standard this engine puts out 177bhp,you can chip them up to 250bhp, giving over 300ftlbs of torque,the 06/07 engine is all alloy block and head the only problem is cost,anything with BMW on it,even 2nd hand is expensive,and then there's whats it going to drive like,big wollop of power for 2000 rpm in each gear,and bags of torque,could make for interesting drive.
Heres a link to a guy who remove his bike engine to fit a 1.8 ford TD and thinks its better
http://westfield-world.com/pics_paulr.html
PAUL FISHER
posted on 22/7/09 at 11:53 PM Reply With Quote
Ninehigh
posted on 22/7/09 at 11:57 PM Reply With Quote
My thoughts exactly:
That westfield page says
It's a Ford Escort 1800 Engine with a turbo which gives it a bit more go it put out a round 120 bhp mark which for power to weight is just right.
Car weight is around 620 kg so works well. l had bike engine in it but this is so much fun and I'm getting round 65 mpg and that's with giveing it some all the time. It just comes back for more and it's all round fun.
DRC INDY 7
posted on 23/7/09 at 12:06 AM Reply With Quote
I currently thinking about ford focus/peugeot 1.6 tdci 16v 110bhp in standard trim 300ftlbs with overboost standard so with a tweek should be rapid 50 mpg in my focus and thats giving it some push
Puddle Dodgers Club
blakep82
posted on 23/7/09 at 12:51 AM Reply With Quote
in a few years i would strongly consider putting a diesel in my car. too late to change plans now, but when i want a new engine, turbo diesel looks fun
Ninehigh
posted on 23/7/09 at 12:58 AM Reply With Quote
See I'm at the stage where I'm in the market for a welder, so maybe an engine similar to the one in my current car, got the manual for it already
l0rd
posted on 23/7/09 at 05:13 AM Reply With Quote
What about the Nissan Navara engines.
flak monkey
posted on 23/7/09 at 06:08 AM Reply With Quote
I think they are 300Nm std not 300lbft
The VAG 1.9 PD diesel is available as std up to 150bhp and very easily remapped to about 190bhp and 320lbft.
The only issue to get over is the gearing, you need a really short first so bang goes your 0-60 time. However once its rolling you are on a winner if you can put the power down.
You also have the issue that it just doesnt sound as good as a petrol...
Sera
http://www.motosera.com
hughpinder
posted on 23/7/09 at 07:16 AM Reply With Quote
I suspect the major problem will be stopping wheelspin with all the torque, and so little weight...
posted on 23/7/09 at 07:44 AM Reply With Quote
Rover lump L series as used in the Rover 95 as standard easy to get 125.
The BMW diesel as used in the 75 and Freelander can produce a lot more power but it is also a lot heavier
wilkingj
posted on 23/7/09 at 08:04 AM Reply With Quote
No one has mentioned the required 3.14 or 3.38 Diff. These will be almost mandatory if you are using a diesel engine.
Volvo D5 ?? remapped will make 200+bhp and about 400 ft lb torque, and they will do 55mpg
(even in the volvo body!)
And I believe they are an all ally engine.
Lots of options, but crappy sound track.
Still you could run a big Hi-Fi and run a MP3 player connected to the throttle to get the sound track sorted
Then there is the Audi or the BMW as mentioned above.
All things are possible. It just depends on what you want.
IMHO:
I do less than 2000 miles a year and a petrol V8 is still worth it.
If I was doing 10k a year it would be a completely different matter.
Best Regards
Geoff
http://www.v8viento.co.uk
James
posted on 23/7/09 at 09:23 AM Reply With Quote
That recent article in PPC was about a guy fitting a diesel engine in a Westfield. I can't remember the engine of course, but think it was probably a VW.
James
Volvorsport
posted on 23/7/09 at 09:38 AM Reply With Quote
ford diesel to type 9 box IIRC for the PPC car .
find a RWD M(0 for the whiteblock , in slots the D5 , now , if you think its a crappy soundtrack , you should have a go in one .
the BIG problem is removing the ECU to run the thing unless you can get an aftermarket one to work , see most modern ones have a trap and need some sort of software to prevent damaging it - otherwise its easily £1k to replace .
the vw LT 2.4 intercooled six can make some big power , and in volvo form comes with a rwd box , but its not popular
www.dbsmotorsport.co.uk
getting dirty under a bus
Guinness
posted on 23/7/09 at 11:03 AM Reply With Quote
As said, I thought the big stumbling block on using a modern diesel was the lack of aftermarket / standalone ECU's and / or the complexity of trying to get the OEM one to work when removed from it's natural home in the rep mobile.
I'd imagine there would be a big market for a Megasquirt equivalent for oil burners.
Mega glow anyone?
Mike
blakep82
posted on 23/7/09 at 11:13 AM Reply With Quote
how do diesels work? i thought glow plugs were only used to warm the engine up, and they ran on their own after that?
what would the ecu do?
Guinness
posted on 23/7/09 at 11:15 AM Reply With Quote
In simple terms they control the amount of fuel injected.
Diesels run at wide open throttle all the time. The accelerator pedal just controls the amount of fuel put in. Think of it like a foot operated tap!
On modern diesels they control all sorts of stuff, exhaust gas recirc, over boost, smoke control etc etc.
Mike
cd.thomson
posted on 23/7/09 at 11:16 AM Reply With Quote
fueling is complex on a diesel i think.
where is dinosaur juice when you need him
Craig
Volvorsport
posted on 23/7/09 at 11:32 AM Reply With Quote
yeah , the common rail engines with electronic injectors are hard to swap over , more basic ones with mechanical fuel pump are a lot easier .
in PPC theres a company that offers a diesel standalone , dont how much it is tho .
dinosaurjuice
posted on 23/7/09 at 01:06 PM Reply With Quote
turbo diesel are great fun in kit cars
i use a 2.0tdci (actually a new generation peugeot hdi) running 136 hp. the 136hp isnt massive. neither is the 4000rpm peak power. but the fun you can have with 320nm at a measly 2000rpm is AWESOME
my first choice was the 1.6 TDCi. but i couldnt find a working donor car for the right money...
there are currently no (or very limited) aftermarket ECU's available for common rail diesels. its a case of finding a car which will allow the ECU to work without stropping to much when it cant find the ABS pump etc.
the VW 1.9tdi is an easy install - these have very simple ecus.
will
whitestu
posted on 23/7/09 at 01:48 PM Reply With Quote
No!! this is all wrong - diesel engines are horrible things.
Bike engines are perfect for these cars, or a nice free revving petrol engine, but not a diesel.
Ninehigh
posted on 23/7/09 at 02:04 PM Reply With Quote
IMHO:
What about that 2.57 (ish) one BMW has? I forget which way round the numbers are, which way it goes for better acceleration.
And yeah I do over 10k a year
<<  1    2  >>
