Author: Subject: remote gear linkages
novacaine
posted on 24/7/09 at 05:10 PM Reply With Quote
hi all,
im well and truly fed up of the gearchange on my punto JTD (X Reg)
it is the most vague, stiff and unreliable gear change setup i have ever used,
it is very stiff as said above, this can usually be solved by removing the linkage and scuffing it with a bit of wet n dry but im getting to the point now where im doing that every month or so,
secondly the lever wont self center, if i pop it out of 1st the lever will stay on the left side
so my question is, if I got a remote gear change unit off a different car with the same shift pattern could i use it on my car without too much difficulty?
in cant see too much wrong with that idea, maybe i would have to adapt the lever where the cables attach to account for different throws of the cables
thanks in advance
Matt
Guinness
posted on 24/7/09 at 05:17 PM Reply With Quote
Sounds like a lot of bother. Has it always been like this? Or has it got worse over time?
I'd be looking at taking the cables out and replacing them. There may be a kink / heat affected area in the existing cables?
Mike
ashg
posted on 24/7/09 at 05:44 PM Reply With Quote
use the linkage off the bravo. its much smoother and should fit.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
