Author: Subject: megasquirt x-flow map needed
myeates
posted on 31/7/09 at 11:14 AM Reply With Quote
Hi all im currently upgrading my crossflow to injection and need a suitable map to run on it.
has anybody got a map loaded anywhere that i can use. cant seem to find one anywhere.
have an ignition map that i had on my megajolt but need the fuel side of it.
big_wasa
posted on 31/7/09 at 03:31 PM Reply With Quote
Paulf ran his on Tb's before going zetec
myeates
posted on 31/7/09 at 03:54 PM Reply With Quote
thanks mate tried him first him and clairetoo have lost theres unfortunately but they have both been very helpful
thanks
Mark
paulf
posted on 31/7/09 at 08:21 PM Reply With Quote
If you cant find a MAP then it is not that hard to start from scratch.As long as you know the injector flow rates and enter them it will start on the basic map in the processor.You would then get the idle and lowspeed settings somewhere near and develop a map from there.
You will really need a wideband sensor and a lap top or PDA to datalog with, although i got my cross flow running ok with a narrow band sensor and guess work.
If you go to www.extraefi.co.uk there is lots of info on there and a set up CD that can be downloaded with base maps on it.
Just had a look but noo crossflow maps although there are some Edis set ups which may help.
Paul.
