New Topic New Reply
Author: Subject: Anyone extended their footwell?
goodguydrew
posted on 17/8/09 at 09:40 PM Reply With Quote
I have shortened my car by 4 inches in the seating area. To gain the leg room back I was planning to extend the drivers foot well.
1. Do you think I need to? (I'm 6ft)
2. If you have, ant pics and advice?
I know Caterham did/do this.
I think I may run into problems with the bellhousng restricting space.
Cheers.
madteg
posted on 17/8/09 at 09:50 PM Reply With Quote
Leg room
I put the sheet steel on the inside of the tunnel and gained 25mm all the way down. If you look down my foot well you can see the box section, hope this makes sense
goodguydrew
posted on 17/8/09 at 09:57 PM Reply With Quote
I meant the leg room length, not width. Cheers.
madteg
posted on 17/8/09 at 09:59 PM Reply With Quote
goodguydrew
posted on 17/8/09 at 10:00 PM Reply With Quote
You have a very understanding wife!
dmac
posted on 17/8/09 at 10:10 PM Reply With Quote
Madteg has a point though, the further forward you take the footwell the narrower it gets, the standard footwell is a bit tight for my feet.
Whether you need it or not really depends on your leg length, not your total height, I'm over six foot but the back of my seat is about 3 inches away from the rear bulkhead to get the right driving position, but then I have a long body and short legs for my height.
Duncan
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 17/8/09 at 10:35 PM Reply With Quote
Originally posted by madteg
Sorry its the alcohol
Surely this is a photoshop!!!!!
RichardK
posted on 17/8/09 at 11:08 PM Reply With Quote
Why, what's up its on a trolley so won't mark the floor, can't see the problem myself
Rich
Gallery updated 11/01/2011
snippy
posted on 17/8/09 at 11:15 PM Reply With Quote
Being 6ft 3 (and a bit) I had to extend my drivers footwell on my Tiger due to having long legs. I also used standard Sierra pedals which I had cut, bent backwards and then rewelded. This meant they would travel further once depressed than the tunnel end panel would allow. By extending the end panel the pedals travel easily into the `extended area`. I basically made an ali box and riveted it on the end of the footwell. Couple of pics attached for you.
Nick
snippy
posted on 17/8/09 at 11:16 PM Reply With Quote
inside view
907
posted on 17/8/09 at 11:57 PM Reply With Quote
Similar to above really.
In the end of the foot well I cut a hole and made up a box that bolted in.
On the end of the box mounts the M/C's.
The pedals then hinge from the end chassis cross member.
Humbug
posted on 18/8/09 at 07:14 AM Reply With Quote
Paul - are they Lexan panels you've got on the sides?
907
posted on 18/8/09 at 07:44 AM Reply With Quote
3mm Liteply covered in 15mm hard foam (kneeling mat type stuff) with grey vinyl stretched over and glued.
Blue vinyl for the rest.
posted on 18/8/09 at 08:19 AM Reply With Quote
How did you make the trim panels stay in place; just a tight fit, velcro etc?
907
posted on 18/8/09 at 08:36 AM Reply With Quote
Percussion fit
Paul G
whitestu
posted on 18/8/09 at 09:29 AM Reply With Quote
The type of seat you use makes quite a difference. Fibreglass seats give and extra 4 inches ish of leg room over Cobra Roadstyer seats.
goodguydrew
posted on 19/8/09 at 10:33 PM Reply With Quote
Thanks for the advice.
New Topic New Reply
